Originally Posted by
NYSTGIII
Don't waste your time with the snow kit... Just get the aquamist HFS-1 .. it comes with the gauge and the failsafe.
Thats the first time ive ever heard a statement like that. Aquamist makes nice prodicts, but they are a royal pain in the ass to deal with...especially if something goes wrong with the kit and you need some tech advice. I used one aquamist kit and immediately switched over to the Snow performance. The pump in the aquamist kit was bad from the factory(run for 5-6sec's then overheat and shut off), and i couldnt get a straight answer from anyone at Aquamist. Called up the people at Snow and they walked me through fixing the thing. We got it running and it performed well...but we decided to go with the Snow kit just because of their tech support.
Unless your IAT's are insanely high, this kit wont do much out of the box. You wont really see any nice gains until its tuned to compensate for the water/meth. I really dont see how the TB could rust since its aluminum, but it is possible for rust to transfer from the steel pipes to the tb plate...which can corrode and cause it to stick. Using the correct water/meth mixture will correct this....or you can just run straight meth
