Results 1 to 12 of 12
    Sep 15 2005
    Norwalk, CA
    bulb out warning
    Has anyone installed HID kits in their fog light housing? I put in some 3000k kit but now am getting bulb out warnings. The HID kits are 35 watt while the regular halogens are 55 watt. Can anyone point me in the right direction for a resistor to add in to increase the load? Thank you.
    Peter
    Senior Member Three Rings jrok24k's Avatar
    Feb 19 2008
    B7 A4
    Re: bulb out warning
    i am not positive but i think you have to do a vagcom mod to make it disappear
    Sep 15 2005
    Norwalk, CA
    i did read about someone vag'ing the car for DTM (where no fog lights are installed from the factory). Does that disable the circuit too? Does anyone have other suggestions?
    Jun 05 2007
    Syracuse, NY
    I don't know of any way to recode for HID fogs.
    The best way to do this is to get a 50W hid 'kit'...
    You could make it work by adding a resistor, but I wouldn't recommend it.
    Sep 15 2005
    Norwalk, CA
    I was actually just reading about your LED city light mod. Isn't this similar to what you are doing there?
    Peter
    Jun 05 2007
    Syracuse, NY
    Sort of....but there's more to making the LED citylight work properly than just adding a resistor to trick the computer.
    In your case it is that simple...but 20W is a lot of power (heat) to drop across a resistor.
    Sep 15 2005
    Norwalk, CA
    i'm thinking about getting the "load resistor kit" found on the bottom of this page
    I did the calculation. halogen 55 watt on the car have a resistance of 2.6 to 3.7 ohms, while the 35 watt hid kid have somewhere between 4 and 5.9 ohms. adding the 6 ohm resistor in parallel drops the resistance to between the halogen bulb's resistance. The resistor with it's heatsink is rated for 50 watt. As long as I mount it away from plastic, I should be okay.
    What do you think?
    Peter
    Jun 05 2007
    Syracuse, NY
    You're on the right track with the 50W rated resistor, but the value you calculated isn't correct.
    A 6ohm resistor will dissipate ~30W @ 13.5V...which is more than you need it to.
    Apr 13 2004
    '07 goped
    Main land USA
    a few different places sell the bulb out warning cancelers, I think supreme does, i know Creative Autoworks does
    Jun 05 2007
    Syracuse, NY
    ^^^Not sure what these are, but it sounds like a better option than using a resistor.
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    http://cgi.ebay.com/ebaymotors/ws/eB...004139195&rd=1
    i was recomended these hope it helps
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by peta8368 View Post
    Peter
    Have you found a solution yes?
