Results 1 to 12 of 12
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Driveshaft stabilizer
    When i bought my car I was told that it needed a drive shaft stabilizer. I can feel a vibration when I am in low RPM's in first gear. Anyone know where to get a replacement one and where its even located on the car? LOL
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    Re: Driveshaft stabilizer
    drive shaft stabilizer? you mean a drivetrain stabilizer? theyre aftermarket if thats what youre looking for. www.awe-tuning.com or www.autospeedperformance.com
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    probably the driveshaft bushing. 034 has em.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by Jsmooth65 View Post
    Yeah lol thats what I meant. Those are in the rear correct? I went to 034's site and I couldnt find them.
    Feb 19 2007
    La Crescent, MN
    Am I looking for the wrong thing? I found a driveshaft support, but it doesn't seem like its a stock part, they said they make them in-house.
    http://www.034motorsport.com/product...ducts_id=13696
    Aug 10 2007
    Castle Rock, CO
    Quote Originally Posted by alias747 View Post
    Thats the one. Its not a stock part because it comes with the driveshaft assembly. Audi doesn't supply them separate. Blauparts has this bushing as well, but its been out of stock everytime I looked.
    To see the part under your car, you'll have to remove your catback and drop the heatshield. Do a little searching on AW and you can find the diagram from the Audi parts catalog somebody posted.
    Feb 19 2007
    La Crescent, MN
    Ok good deal, yeah I will have to order from 034, plus on Blau its like 80 bucks more! So I take it this is something that is freakin hard to do yourself?
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    WHen your ready to put it in, let me know and I'll help you out.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Aug 10 2007
    Castle Rock, CO
    Kind of. I just ordered a whole rebuilt driveshaft, cause one of the CV's was broken, and that bushing was worn but still usable. Was a whole lot easier than rebuilding a driveshaft myself. I guess you would have to disconnect the u-joint in the middle of the assembly, take off the old bushing, put the new one on and then reconnect that u-joint. Of course, this is with the driveshaft out of the car.
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by gointoscott View Post
    Sure thing bro! And you need to tell Huri that he should get me a better deal than 180 bucks for that bushing and get some in stock!
    Feb 19 2007
    La Crescent, MN
    Crap got any idea how to do it with the driveshaft still on the car? But in other words, it probably not going to be a very easy task?
    Aug 10 2007
    Castle Rock, CO
    I think you can disconnect the u-joint with the CV's still attached. But you should probably support them somehow (jackstands) while you replace the bushing. Don't let them turn either.
