Results 1 to 8 of 8
    Senior Member One Ring
    Mar 18 2008
    Powers
    19x8 ET 30 w/245 tires- will these fit an A4?
    I was given Harmann RS6 reps in an 19 x 8 (maybe 8.5) rims ET with 245 tires on them. I have OEM sport suspension. Will these rims fit my 2008 A4? Will it rub? If 245 is too big, will switching to a 235 allow them to fit?
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: 19x8 ET 30 w/245 tires- will these fit an A4?
    Can't speak for the wheels, but 245/35-19 is the only size that meets load for the car.
    Jun 14 2005
    Anaheim, CA
    The tires will rub depending on offset. Get the exact specs and let me know and i can help you out.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Mar 18 2008
    Powers
    Charles the Rims are 19 x 8 with ET 30. Tires are Michelin pilots in 245/35 19. Do you think they will they rub? If so, back and front or only back?
    Jun 14 2005
    Anaheim, CA
    Looks like the most aggressive offset i would recommend is a 19x8.5 +35 offset on a 245/35/19 tire. With a 19x8.0 +30 on a 245 i think you should be ok. You might slightly rub over some large bumps or with a full cabin probably. Cant guarantee anything.
    -Charles@VMRWheel
    Mar 18 2008
    Powers
    Thanks Charles!
    Veteran Member Three Rings RAUDIS6's Avatar
    Oct 09 2006
    Stage 3 B5 S4, LS460, Mini S Countryman
    Not a good choice for your car, sell them to me. LOL!!!
    Registered Member One Ring imaphaetonguy's Avatar
    Apr 04 2008
    Houston
    I'm running 245/40/18 tires on 18 x 8 et30 rims on my B7 Sline. No rubbing.
