Results 1 to 3 of 3
    Nov 26 2007
    sway bar part number
    Does anyone have the part number for the rs4 rear sway bar ?.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    Re: sway bar part number
    I'm not going to flame you like others would but you should try using the SEARCH button.. but heres the part number- 8E0-511-409-AL
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
    Registered Member Two Rings coryliv's Avatar
    Feb 09 2006
    VA
    Also check the FAQ section at the top of the B7 forum. Its got a lot of info and may answer some future questions.
    Regarding the RS4 bar the FAQ section has bracket part #'s as well. If you buy the sway bar kits from sites like ECS tuning they don't sell these brackets with the kit (only bar and bushings). Reusing the stock ones leads to squeaking and other noises with the bar due to its larger size (I reused stock brackets). I'd suggest ordering these as well. It should make your installation go a lot smoother.
    For install instructions check out this link...
    http://www.a4mods.com/index.php?page...s/swaybar.html
    ________________________
    2006 A4 2.0T Quattro
    Moro blue, grey leather, 6 spd, sports suspension, GIAC, RS4 rear sway
