Results 1 to 14 of 14
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    B7/S4 Rear Brake Upgrades?
    I just bought a BBK for my car and have been searching for an upgrade for the rear, and am having very little luck. There is no way that I'm gonna pay $2500 for the rear Brembo kit either. Other than pads & lines, has anyone found a slotted rotor upgrade for the rear, 300mm? thx
    Account Terminated Four Rings
    Mar 09 2005
    Widebody S4 Noobs Destroyed: 9
    Santa Clara, CA
    Re: B7/S4 Rear Brake Upgrades?
    s8 carriers and rotors with ss lines and good pads
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    stasis? ecstuning?
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Dec 28 2005
    NY/NJ
    is 300mm the stock rear brake rotor size?? i forget but if it is, look into spp's slotted/drilled/dimpled brake rotors...
    http://audizine.com/forum/showthread.php?t=186185
    Current: 2024 SQ7, 2021 RS5
    Sep 17 2007
    Quote Originally Posted by ngng View Post
    Sounds interesting. Any reference that I can check to see the set-up (all the parts needed to do the install, ie springs,clips whatever), costs etc. Do you have this set-up? Thx
    Established Member Two Rings dtm4me's Avatar
    Mar 24 2008
    04 A4 1.8T USP APR 3+
    Atlanta GA
    s-fore, I have been searching myself for a decent rear upgrade...Stasis offers 300mm 2-piece rotors which would use our stock calipers for $800. Otherwise you can try to source the B7S4 rear set-up which would require the calipers, rotors and carriers. That's really about it besides the rear BBK from Brembo.
    Nothing exceeds like excess!
    USP CLUB MEMBER #103
    Sep 17 2007
    /\/\, I have a B7S4. I am looking for something a little better than the stock rotor, slotted. Its funny how zimmerman, stoptech, power stop and brembo(sport set-up) all offer nothing for this car. BTW, stasis is "2 weeks" out on the release of their kit, as is stoptech stage 2 and zimmerman. Damn, no one believes in this car.
    Veteran Member Four Rings Jrunr's Avatar
    Oct 27 2004
    2007 Audi S4, Phantom
    El Paso, TX
    I am curious about the S8 kit... tell me more...
    Veteran Member Three Rings Meradin's Avatar
    Jul 14 2005
    White Plains, NY
    I got slotted rotors and SS lines from Stoptech to match my BBK and painted the calipers to match.
    2012 S4 Prestige S-Tronic
    Phantom Black /w Titanium Package
    Modded...
    Sep 17 2007
    Quote Originally Posted by Meradin View Post
    Would you by chance know a part/kit number for the rear rotors? I called Stratmosphere, GMP(where I got the front BBK) & others and they said that a rear rotor is not available from stoptech. What seemed to be most common is the offer to drill or slot a set of OEM rear rotors which I may very well do and just paint the centers black to match the brembo fronts.
    Sep 17 2007
    Just a little info for anyone thinking of a rear brake upgrade for a B7 S4. I searched High and Low and ended up with the following: Rear Slotted "Stock" Rotors fron ECS (Interesting, cause they came in a Zimmerman Box and Zimmerman does not have anything listed, aparently, for an upgrade for B7 S4), Stoptech rear SS Lines and Carbotech Pads. All in, about $390 which is a far cry from $3K for the Brembo Kit. I did get a 355mm Brembo 6 Pot for the front, and really wanted a decent upgrade for the rear, not over the top that matched the front kit too. Just a little FYI.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by S-Fore View Post
    Don't say 2 weeks!
    Registered Member Two Rings Lake Powell's Avatar
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    I don't mind the rear rotor on my B7RS4, looks OK to me, but the rear caliper looks pretty cheap. Any leads on an upgraded rear caliper?
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    i might be crazy but i 100% HAD stop tech rear rotors that were drilled on the back of my b6 s4 and a set of 6 piston stoptechs up front. ill try and find pics there on an SD card somewhere... there options were slotted or drilled but not both
    ps
    Lake Powell: i love the look of the rear rotors on mine aswell but if the hub of the rotor was painted or powder coated in black to match the front... it would look 10 times better
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
