Results 1 to 13 of 13
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    Turbosmart Eboost
    Where's the best place to purchase a Eboost gauge? Ebay has them ranging from $400-$450 I've seen them online as high as $650? Also does anyone make a podi to mount on the steering column to fit this size gauge. I'm just using it for boost control functionality.
    Feb 17 2005
    Sarasota, FL
    Re: Turbosmart Eboost
    No one makes a correct size pod for them for our cars, your stuck making your own or coming up with something.
    Here's where I have had mine, may give you some ideas
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Not true, they now have a standard 2 5/8 EBoost, I saw it yestarday on their website. Shawn, did you get my EBC PM?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    Quote Originally Posted by matt7127 View Post
    http://www.4induktion.com/catalog/pr...roducts_id=132
    only $260 and its a real clean look
    Mar 21 2006
    Lakeland, FL.
    Thats just a gauge, Eboost is a controller also.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by dirtybrd View Post
    Hmm, says new for 08', its about time they made a better fitting size. Yes I got your PM, I dont have a source for any of them unless Im buying in quantities, your better off E-Bay'ing one
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    anyone have a link to the 2 5/8 eboost gauge? That would be perfect.
    Feb 17 2005
    Sarasota, FL
    http://www.turbosmart.com.au/index.php?id=42
    The 2 5/8's are under the 60mm
    Mar 27 2005
    87 Scirocco 16V
    Hinsdale NH
    Does anyone know what size the AWE Boost gauge is?
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    2 5/8 is the large eBoost like I have.
    You can get it in 2.25" I think it will fit in a Podi.
    I have mine mounted here. I use a Autometer Honda Civic gauge pod I bought on Summit Racing for about $16
    The pod was almost a perfect fit, I had to shave about 1/4" off of one side to make it a perfect fit.
    I know everyone thinks pillar gauges are rice, for me though it is function over form...I can switch boost maps immedeatly on the fly, recall my peak boost and see what my boost levels are without ever taking my eyes off the road
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Turbosmart makes them in 60mm, but it looks as if the Podi only accepts up to a 52mm gauge
    Aug 18 2010
    mazda rx7 circuit racecar, Mitsubishi EVO 8
    Sydney, Australia
    You can get an e-Boost dashboard, pillar or a roll cage mount: http://www.turbosmartonline.com/index.php?id=41
    Alternatively, you can opt for the DIN sized e-Boost STREET.
    Spec list here: http://www.turbosmartonline.com/index.php?id=42
    Thinking Performance?
    Think Turbosmart!
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    wow! 2.5 year advertising necrobump!
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
