Results 1 to 3 of 3
    Established Member Two Rings Renga's Avatar
    Sep 07 2005
    Stockholm, Sweden
    Brake upgrade question.
    Thinking of upgrading my brakes and i´m choosing between the B6 S4 brakes or the 2007 2.0T Brakes.
    Is both of them bolt on?
    Can I use the brakes from the rear brake to, is it bolt on?
    Sorry for the bad English
    Mike from Sweden…
    Veteran Member Four Rings Condo's Avatar
    Jan 30 2007
    2001 S4 Avant
    Cincinnati, OH
    Re: Brake upgrade question.
    Quote Originally Posted by Renga View Post
    Mike from Sweden…
    I went with the B6 S4 brakes. The B7 calipers are about 8mm wider and will have wheel fitment issues. Both are bolt on. I know that the B6 S4 rears will also work but I'm not sure about the parts list. You should find some details at the bottom of this page.
    Veteran Member Four Rings Audized's Avatar
    Oct 22 2006
    Eh?
    I agree with Condo. Go with the B6 S4 setup so you won't have wheel fitment issue. Yet, 19" BBS CH's will clear both B6 S4 and B7 setups.
    Yes, both are bolt-ons. Just a heads up, one of the bolts on the carriers at the back is very hard to remove.
