Results 1 to 33 of 33
Thread: Innovative smic
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Innovative smic
    Did anyones use this. Just want to know if they fit well or more precisely what do i have to do with front fenders and radiator support?
    Senior Member Two Rings BB2001S4:Tim's Avatar
    Oct 04 2006
    NY/NJ/CT
    Re: Innovative smic
    Pics? Where is it from.
    Veteran Member Four Rings raketeS4's Avatar
    Feb 14 2006
    2000 B5 S4 Stg II+, 1977 BMW R100/7
    Re: Innovative smic
    are you referring to the IPP side mounts? I have them, the installation wasn't that bad and I only had to trim a little bit of the rad support... as for performance, they are just slightly better than stock IIRC, i wouldn't have installed them if i didn't get them for free
    2000 B5 S4 Stg II+
    Senior Member Two Rings Brett0712's Avatar
    Jul 28 2007
    MA
    Re: Innovative smic
    Yeah ummm... I wouldnt buy them if you plan on going with more boost. I bought them at a decent price and I got my Stg3 tuned on friday at EPL. Tony logged an IAT delta of almost 50degrees. Granted that was on a dyno with just airflow from the fans, but still. So I am canning these things and going with the ER side mounts.
    Aug 30 2007
    nyc
    Re: Innovative smic
    was that the IPP rs4 smic????
    c5 A6 tip
    this n that
    Jul 28 2007
    MA
    Re: Innovative smic
    No... I have S4 replacement ones... I hear the RS4 replacement ones are a bit better.
    Aug 30 2007
    nyc
    Re: Innovative smic
    i am getting em soon let u know how they r
    c5 A6 tip
    this n that
    Jul 28 2007
    MA
    Re: Innovative smic
    Good luck with them, hopefully the RS4 ones are better.
    At this point, id rather tie mine to my car and drag them down the highway then try and sell them! From day one they have been a pain in my ass. Took me a solid month to get the damn things, the lower mounting tabs dont line up like they are supposed to, and over all they suck as far as performance goes. Shame on me though, I should have listened to the posts about them,
    Aug 30 2007
    nyc
    Re: Innovative smic
    i think with smic's size does matter!!!! [O_O]
    c5 A6 tip
    this n that
    Jul 28 2007
    MA
    Re: Innovative smic
    Which is why I'm canning these for the ER intercoolers!
    Aug 30 2007
    nyc
    Re: Innovative smic
    they are the biggest if u can swallow it!!!! ok ok im done with the innuendo
    c5 A6 tip
    this n that
    Mar 11 2008
    north east
    Re: Innovative smic
    1395 large...
    is anyone running asp's front mount?? thats thing was over 2k from what i remember. they have no info on their site anymore.
    Oct 14 2007
    Val-Belair
    Re: Innovative smic
    Thank's for your thoughs everyones. It helped me to make decision for fmic.
    Re: Innovative smic
    i have the ipp rs4 smic, on my stage 3 it has about 15 degree delta, search my post and you will find a thread with logs
    Jul 28 2007
    MA
    Re: Innovative smic
    No doubt the IPP RS4 replacements are better than the S4 replacements... I wasnt aware there were two different models when I bought mine.
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    Re: Innovative smic
    Quote Originally Posted by silky View Post
    1395 large...
    a couple people on AW did tests and found that temp only slightly dropped. ERs FTW, or ebay FMIC for the cheap (JHM). Don't fuck around w/ IPP or RS4
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Aug 30 2007
    nyc
    Re: Innovative smic
    ipp rs4 are somewhat new........ anythings better than stock and i dont wanna cut up my bumper or spend 1500 ............
    c5 A6 tip
    this n that
    Veteran Member Four Rings revhards4's Avatar
    Feb 14 2004
    Michigan
    Re: Innovative smic
    I have s4 IPP replacements and like them alot. IAT delta is better then stock and compares to OEM RS4 without all the hacking and hose replacements. Of course the ER's are better but look at the price, twice as much. When I go GT eventually I'll run ER's but until then I'm happy.
    Oct 14 2007
    Val-Belair
    Re: Innovative smic
    What does ER means. I mean what's the name of company. Where i can find them. I want to know if they worth-it or should go for cut and FMIC.
    Jul 28 2007
    MA
    Re: Innovative smic
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Re: Innovative smic
    I know that the claim to fame for the IPP S4 SMICs are the fact that they are a direct fit with no modifications to the car needed at all. Is the the same for the IPP RS4 SMICs ?
    Jul 28 2007
    MA
    Re: Innovative smic
    From what ive read and seen... No! You have to cut material away just as you would if you installed regular RS4 intercoolers.
    Oct 31 2007
    Grand Rapids, MI
    Re: Innovative smic
    there are logs that show ipp only dropped ambient delta 3 degrees, thats not worth it imho. go ERs or go home, and ERs are like 1350, not 1500. Like I said, if you need to save money, go custom ebay FMIC, just paint it black or something so it doesn't make the front of your car look like hell!!
    MKIV BPM R32 (DD)
    Re: Innovative smic
    ^^^ what do you mean 3 degree ambient delta? you mean there are logs showing ipp with iat 3 degrees over ambient?
    you have to hack the carrier to fit the ipp rs4 ic
    http://www.audizine.com/forum/showthread.php?t=191381
    ^shows ipp ic w/ 10 degree delta and logs from runs
    Aug 30 2007
    nyc
    Re: Innovative smic
    tell em goo... on another note ... how long did the shipping take from when you paid??????
    Ive been waiting and my car is just sitting there!!!!
    c5 A6 tip
    this n that
    Apr 27 2004
    Pacific NW
    Re: Innovative smic
    Quote Originally Posted by Brett0712 View Post
    If that's the case, then what is the appeal of the IPP RS4-SMICs over the OEM RS4-SMICs ? Are they better in performance or are they just better priced ?
    Jul 28 2007
    MA
    Re: Innovative smic
    Quote Originally Posted by dannyn424 View Post
    It took me a fucking month to get the damn things! And come to find out they BLOW
    Aug 30 2007
    nyc
    Re: Innovative smic
    the rs4 are actually quite larger than the regs and a tad bigger than awe........ i think that the size matters on these coolers...... its like computer heatsinks... bigger is always better...... take it to the bank........
    c5 A6 tip
    this n that
    Re: Innovative smic
    my ipp rs4 have better iat delta than the log i seen with rs4, they are alot bigger too took me 1 week to get them
    Oct 14 2007
    Val-Belair
    Re: Innovative smic
    Quote Originally Posted by 2fastS4 View Post
    Where can you find er intercoolers for that price? I just called one of the're dealers in pa and asking 1425.
    Re: Innovative smic
    I'm still waiting for the log that shows a ic that shows a 3 degree drop UNDER ambient that 2fasts4 was talking about
    Active Member One Ring jays01s4's Avatar
    Feb 25 2007
    Chicago
    Re: Innovative smic
    Quote Originally Posted by Reich View Post
    www.gocpt.com was just there yesterday and they have about 5 sets in stock.
    2001 Audi S4 - VAST Stage 3+
    K04s, ERs, Southbend, Brembo, etc, etc
    1997 BMW M3 Sedan - Track Toy
    1978 Camaro Z-28
    Oct 14 2007
    Val-Belair
    Re: Innovative smic
    Ok thanks everyones. a just bought a pair of ER smic from avalon they have competitive $s. I figured out that cutting front bumper would weaken too mutch the front end of my car. I don't want to crap the rad and front of engine b/c a stupid guy go backward with his car and smash my front while parking for exemple.
