Results 1 to 9 of 9
    Mar 20 2008
    00 A6 4.2
    Chicago,IL
    What tire is best for a staggered setup
    im running General's and I get nothin but vibrations.
    Veteran Member Three Rings onewicked's Avatar
    Sep 25 2007
    2001 A6 2.7t
    Dirty Jersey
    Re: What tire is best for a staggered setup
    my brother has generals on his e92 bmw (new 3series coupe) on staggered wheels and they ride great , not noisy no vibrations, maybe you need to get them rebalanced.
    2001 Audi A6 2.7t
    THE C5 UNION
    Past cars:
    1998 BMW 528i Sport
    1995 Eagle talon TSI w/ 6bolt swap(for sale)
    1996 VW jetta VR6
    1998 VW jetta 2.0 Turbo
    AMS AUTOWERKS #1
    Jun 14 2005
    Anaheim, CA
    Check if any wheel weights have fallen off, or your lugs are not torqued down enough. You need at least 6-8 full turns to be safe. Check tire pressures. Do you have any spacers?
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Tires may be worn irregularly, but probably a wheel issue. Have the balance rechecked and check the wheels to make sure they are true.
    Mar 20 2008
    00 A6 4.2
    Chicago,IL
    the tires are brand new and wheels were checked and are perfect. the car has no issues bc they were fine with the 18s. they were balanced and still the problem, could it be bc im putting it on a quattro audi? im getting new kumhos bc the tire place said the kumhos are betters and the generals have nothing but complaints, but luckily im just exchanging
    Jun 14 2005
    Anaheim, CA
    Thats strange... we mount generals all day long and have never had complains about vibrations... Its strange how its vibrating on your 19" and not 18" wheels.
    -Charles@VMRWheels
    Mar 20 2008
    00 A6 4.2
    Chicago,IL
    I guess the General tires were the problem, I just put new Kumho Ecsta's and WOW, what a difference, NO VIBRATIONS, just a smooth ride
    Senior Member Three Rings tivs31's Avatar
    Feb 07 2008
    Lemont IL
    probably a manufacturer's defect, almost posative, I would see if I could get my money back if I was you
    Jun 14 2005
    Anaheim, CA
    Probably bad luck and got a bad tire then. Good thing you got it resolved.
    -Charles@VMRWheels
