Results 1 to 2 of 2
    Jan 29 2008
    ohio
    FS: '98 A4 2.8 Q 5 speed 88,xxx miles
    I am the original owner (a 55 year old engineer) and have taken meticulous care of this car, but after 10 years it is time for a change. Car is hibiscus with black leather interior. All options except automatic trans. Bose stereo with trunk CD changer, sunroof, wood trim, etc. All the maintenance has been done and the car is in practically flawless condition. In addition to what is listed below the oil had been changed every 3000 miles with Mobile 1 and Audi filters since the end of the warranty. There were a few Castrol/Mann changes in there as well. The dealer did the oil changes before then. This car does not burn a drop of oil between changes. I keep a log book with every gas fill up and every $ spent on the car. This is as good an example of this car as you will find. The interior is in excellent condition. The back seats have practacilly never been used. The paint looks good from 6 inches away. No chips, scrapes or door dings.
    $8000
    Will consider a reasonable offer.
    12/98; Purchased
    6/01; 27,200 Control arms, Dealer installed
    4/03; 46,302 LR Diff seal, Dealer installed, replaced diff and trans fluids
    10/03; 47,823 Rebuilt/lubed wiper mechanism
    3/04; 53,700 Replaced rear wheel bearings, Dealer installed
    6/04; 54,092 New Battery
    7/05; 60,472 Timming belt/water pump/replace leaking raditor
    Same time replace springs/shocks with sport suspension
    Viogland springs, Koni adjustable shocks, H-Sport sway bars
    9/06; 69,000 Replace AC lines
    3/07; 75,000 Replace flex joints in exhause sys
    6/07; 77,741 Replace battery
    6/07; 78,000 Rotors, pads,e-brake cables, PVC/vac hoses/suction pump,
    spark plugs, and wires
    11/07; Paint road rash on nose and install clear bra
    12/07; 81,026 New Bridgstone Tires RE090A
    Sorry but I do not know how to attach photos. I will be glad to send photos if you send me an e-mail address.
    [email protected]
    Jan 29 2008
    ohio
    Re: FS: '98 A4 2.8 Q 5 speed 88,xxx miles
    Sold!!
