Results 1 to 21 of 21
    Senior Member Three Rings lowered97a4's Avatar
    Mar 08 2007
    08 turbo busa 09 nissan Gtr
    ct
    piggies+cutouts or custom dp's+cutouts
    should i just save some money and just have the cutouts fabricated on my piggies or have some custom 2.5 inch downpipes made with cutouts on them also. I can get some dp's made for 250 bucks not stainless steel tho, what do u guys think
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    JHM/AMC trans rebuild
    03 Rs6
    Wagner intercoolers carbon fiber shrouds
    Ecu/Tcu tune
    Cats Removed
    Active Member Four Rings
    Dec 11 2006
    Boston
    Re: piggies+cutouts or custom dp's+cutouts
    You can get by with the stock diameter downpipe. Sure the custom one will have some benefits.
    If the $250 is burning a hole in your wallet then go for it.
    $250 is also a really good deal for downpipes, so maybe you should jump on it.
    Stage 3+ RS6's
    Mar 08 2007
    ct
    theres this place in ct pops exhaust, 250 installed im extra with cutouts
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    you can do either, but I would run cutouts with both of them. They're fun and an extra boost of power.
    the homebrew'd s4
    Dec 11 2006
    Boston
    no way...250 with cutouts and installed? impossible.
    Stage 3+ RS6's
    Mar 15 2007
    New England
    yeah, thats crazy, electronic cutouts are around that alone. even manuals aren't that cheap.
    the homebrew'd s4
    Veteran Member Three Rings AielloS4's Avatar
    10' S4
    BOSTON
    id do piggie straight pipes with the cutouts in the main cats place.
    EUROSPORT-PERFORMANCE
    www.eurosport-performance.com
    Dec 11 2006
    Boston
    I run no cats what so ever...and it's a delight.
    but yeah, Tonys idea is good too.
    btw get electric cutouts instead of manual dumps.
    Stage 3+ RS6's
    Mar 15 2007
    New England
    not to threadjack but, I don't run any cats either, in the downpipes or catback, just resonators. it's the ssac set up. is that bad for air/fuel mixture? do the o2's have anything to do with that? I know the downpipe ones don't but what about the cat back portion?
    the homebrew'd s4
    Dec 11 2006
    Boston
    unless you don't have a CEL fix...you will be fine.
    Stage 3+ RS6's
    Mar 15 2007
    New England
    I have a cel but I believe its because I haven't installed defoulers yet.
    the homebrew'd s4
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    If you are going to do cut outs you might as well go all the way with custom dp's. But $250 sounds like an insta-rust exhaust.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 11 2006
    Boston
    ceramic coat them!
    Stage 3+ RS6's
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    I would be highly skeptical that the custom 2.5" will flow better than the stock DP's with gutted precats, and not being stainless, they certainly won't last as long...
    Senior Member Two Rings PoloIceberg's Avatar
    Oct 12 2006
    Bx, Ny
    i say just do the cutouts, the whole point of bigger downpipes is to help spool and relieve back pressure, cutouts/dumps will do just that...either way its up to u
    Mar 08 2007
    ct
    i baught cutouts 125 a piece, my friend got a catback from them it isnt even rusting yet, but thats what i was think PoloIceberg the whole point cutouts is to get rid of backpressure is the .5 of an inch gonna do much and also get rid of that empty champer where the old cat was near the turbo
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    That chamber right behind the turbo is theoretically the reason that the factory DP's with gutted pre-cats do as well as they do. Some very, very fast S4's use these pipes...
    Oct 12 2006
    Bx, Ny
    Quote Originally Posted by lowered97a4 View Post
    what kind of cutouts? where did you get em for that price? i was about to buy the qtp cutouts for 400(pair)
    Mar 08 2007
    ct
    i got these ones off ebay they were refurbeshed it was like these but just the cutout and new cable and switch http://cgi.ebay.com/ebaymotors/Electric-Exhaust-Cutout-E-Cutout-Cutouts-Cut-out_W0QQitemZ170207837418QQcmdZViewItem?hash=item1 70207837418[/URL]
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Mar 08 2007
    ct
    that one is a new one 300 bucks QTP for a pair on the same page on ebay 12 bucks shipping better deal than 400
    2001 s4 stage 3
    Sanitorin Blue
    10secs4 tune
    meth injection
    03 Rs6
    Ecu/Tcu tune
    Cats Removed
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    http://www.quicktimeperformance.com/Controller/
    And they are 15 mins from the GWB. Can even pick them up instead of paying for shipping.
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
