Results 1 to 11 of 11
    Registered Member Three Rings Lumas's Avatar
    04 A6 s-line
    north jersey
    Ipod and XM radio?
    Hey guys,
    Do any of you know if I can use an Ipod connector (through the cd changer input) and an XM radio receiver?
    Former: 1999 A4 1.8TQhttp://www.audizine.com/gallery/data/500/210lumas.jpg
    Current: 2004 A7 S-Line [Pics coming soon]
    Mar 09 2008
    2005 A4 3.0 USP
    CH
    Re: Ipod and XM radio?
    you can you just to buy an additional adapter that will let you do both.. .
    Feb 17 2004
    Sterling, VA
    I'm running the Neo Prolink on my car. I have the Symphony II radio with BOSE and factory installed XM. This is for my iPhone and it also retains the factory steering wheel controls too.
    Great piece of hardware.
    Here's where I got mine from:
    http://www.icarkits.com/advanced_sea...icle=1&sort=4d
    Here's the manufacturer's product description page:
    http://www.neocaraudio.com/product_i...oducts_id=1035
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Veteran Member Four Rings FrankA6's Avatar
    Mar 30 2008
    2004 A6 2.7T, 2012 Volvo S60 R-Design
    Pittsburgh
    Daft i have a 2004 S-Line, and i see you have a 2004 also, where do you connect that to?
    Nevermind! i just looked at the site, so it goes behind the factory radio, and you run the cable out, do you like it?
    2004 Audi A6 2.7T
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by FrankA6 View Post
    I don't like it..................
    I LOVE IT!!! hehe
    No, seriously, it is a great device. I will admit that getting the radio out of it's hole is a tad tricky, but otherwise it was all cake. I did take the time to drill a hole in the glovebox's back corner to run the cables into there. This allowed me to mount the prolink's brain in the glove box in-case I wanted to attach an AUX-in type device. Also it make it easy to access it if I wanted to change the dip switches on it.
    I ended up running the interface cable to the opening behind the e-brake and my iPhone sits on that surface while driving (it's top edge buts up against the side mirror control knob). The only issue I've had is that if I leave the iPhone's antenna enabled, it will occasionally cause the music to stop and I have to tap the play icon on it again. On a regular iPod, this would not occur.
    Brett - Moderator
    Issue?: email me.
    Veteran Member Four Rings 2.slowT's Avatar
    Sep 24 2006
    2002 Audi A6 2.7T
    Minneapolis MN
    Hey Daft - Just posted on XM install can you take a look?
    2002 A6 2.7T Sport
    2000 A4 Avant Daily
    C5UNION | pictures & timeline
    Veteran Member Four Rings wofman's Avatar
    Apr 01 2008
    2010 Jetta TDI
    Does the Symphony-Bose system show the ipod info on the in-dash display when you use neo prolink? If not, I gues it helps to have ipod where you can see to scroll play lists, etc. I have Symphony (as opposed to II) and understand the set-up is basically the same. Also, "DICE" has similar config. available -- not sure how they compare. Hoping to hear some pros/cons. Definitely want to keep radio and steering wheel cont'ls (both do that).
    Nothing going to bring it back: 2000 C5 2.7T 6sp MT
    Ming Blue, S6 Blades, EuroSpoiler,
    GIAC-93, AWE DPs to Milltek Catback,
    RS4 Clutch, JHM DT-Stabilizer, VAST Short-Shifter,
    H&R Sways, Eibach Pro-kit, Bilstein Sport Shocks, etc., ...
    NOW: '10 Jetta TDI w 6MT, Revo Tune Commuter Car
    Apr 01 2008
    2010 Jetta TDI
    Senior Member Two Rings sleeprr's Avatar
    Jul 05 2008
    94 90 sedan, 95 318TI....wifes
    Coeur D'Alene, Idaho
    *subscribed*
    curious to see if the symphany-bose displays text with the neo ipod hookup
    Veteran Member Four Rings A6.S-line's Avatar
    Nov 29 2008
    NYC and NJ
    I doubt it: b/c if the Neo uses the CD Changer connection at the back of the head unit, then the answer is no. It is not the adapter kit's fault - Symphony doesn't have any text capability thru that input.
    It has been mentioned on an older thread that Dice was working on an adapter that worked thru the Sat Radio input, and thus gaining text/id3 capability. Don't think that ever happened tho
    Apr 01 2008
    2010 Jetta TDI
    DICE told me they require unit with SAT for text display
