Results 1 to 8 of 8
    Registered Member Two Rings
    Feb 12 2008
    A4 2.0T Q- Ocean Blue Opearl
    Wayne, New Jersey
    RS4 Wheels on B7 A4
    i was looking on ecs tuning an dit says the et is 29 how does that fit on teh B7 A4 (spacers) any pics thanks
    Veteran Member Four Rings LAS's Avatar
    Feb 12 2004
    HI.
    Re: RS4 Wheels on B7 A4
    those are real OEM rims that run at OEM offset made for the rs4's wider OEM fenders. it will stick out slightly pass the fenders, and even much more with spacers.
    also, those wheels are heavy.
    search user KryptoniK
    Veteran Member Four Rings autoverruckt's Avatar
    Sep 26 2004
    STL
    Won't work not only because of the offset but the overall width as well - you can call ECS for advice.
    04 A4 USP 1.8TQ 6MT Silver | GIAC | evo dv
    05 S4 6MT silver
    07 A4 2.0TQ Black | APR93 | Eibach/Koni Sport | oem B7S4 18's
    03 A4 Avant 3.0L Silver | oem B7S4 18's | 10mm rear spacers
    14 A4 2.0TQ Silver | APR93 | S-Line Pkg| Cold Weather Pkg | 12mm rear
    Present:
    20 Q5 Manhattan Gray | Titanium Sport Pkg | Black Optic pkg
    23 S4 Chronos Gray | Premium Plus | S Sport pkg | Sport exhaust
    Nov 05 2007
    Oregon
    You want the VMR replicas instead.
    Check with purems.com. Avail in silver, gray, or black. Have 'em, love 'em. They are heavy, that is true, but one gets them understanding that they're a decent quality wheel that looks great.
    Jun 14 2005
    Anaheim, CA
    In here kinda late, but those offsets are OEM Rs4 wheels which wont fit your vehicle. If you would like Rs4 style wheels that fit correctly for your vehicle, contact me directly at [email protected]
    www.velocitymotoring.com
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    The RS4 OEM wheels will work just fine provided you get some RS4 fenders.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Feb 12 2004
    HI.
    then you'll need rs4 front and rear bumpers...so yeah, it's doable.
    Established Member Two Rings buk8tee's Avatar
    Apr 05 2007
    Florida
    It'll fit you guys are just a bunch of pansy's. hahahaha
    just can't go superlow on the oem rs4's. i put a set on my b7 a4 when i had stasis coils and it sat perfectly in my driveway. now if i were to go for a drive that's a different story all together. i'd have to raise my car from roughly 25" fender to ground all around to something like 26.5" fender to ground all around. since the body will still somewhat roll under hard cornering...you will definitely be rubbing if you try to keep the car low!!!!
    quick fix would simply be to widen the fenders an inch or so w/ metal by a reputable body shop and voila....one of a kind b7 (non-rs4) w/ widebody and oem rs4's to boot. tell me who isn't gonna envy that setup??????????????????
