Results 1 to 4 of 4
    Registered Member Two Rings
    Nov 09 2007
    Philadelphia, PA
    03 B6 healdight repalcement
    I've been trying to replace the drivers side headlight on my 03 B6 and have yet to succeed. The access box is right up against the power steering reservoir so I think the entire headlight unit needs to be removed. I've tried removing the two torx screws on the top. Are there more hidden screws that I need to remove. I've got inspection coming up soon and need a fix asap. Does anyone have a link to a DIY article for changing headlight bubls?
    Thanks
    Veteran Member Three Rings a4 turbo's Avatar
    Nov 25 2007
    Fresno California
    Re: 03 B6 healdight repalcement
    just take out your headlight...thats what i did....there are only four screws total
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Down about 4-5 inches behind the headlight assembly there are 2 more torx bolts. You don't have to remove them just loosen them about 5 turns and the light will slide out.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 06 2007
    B6 A4 1.8T MQ, B7 A4 2.0t MQ, B8 A4 Avant 2.0T K04
    There are two more torx that sit behind the light, just get a flash light and look behind the light for two torx bolts. They are not that hard to get to but you will need about a 6" extension. The good thing is all you need to do is loosen the bolts and you will be able to slide the headlight out enough to access the light w/o having to completely remove the light form the car.
    --Adam
