Results 1 to 21 of 21
    Established Member Two Rings BigChris's Avatar
    May 20 2007
    2014 Q7, 1992 MB 300SD, 1990 Miata 320whp
    Bergen County NJ
    GT28RS with Selet Plus
    First off here's my setup:
    GT28RS kit from Eurocode with REVO programming
    AWE FMIC
    AWE Exhaust
    Carbonio Intake
    ECS Stage 3 Coil Pack
    Bosch Plugs
    Bailey DV
    Select Plus and Vag Com.
    I keep reading posts and hearing about people who's setups pull extremely hard and think that I might be missing out on something. My car does pull hard but I feel like there should be more. With the Select Plus I've set my car to boost level 6 and timing at 4. I'm not exactly sure what my boost is since my boost gauge is not hooked up (broke my tee connector).
    Any ideas?
    "It is what it is..."
    2007 Jeep Grand Cherokee Hemi
    1992 Mercedes 300SD
    2014 Audi Q7
    1990 Mazda Miata - 306whp @ 18psi - track car
    May 24 2007
    Southern California
    Re: GT28RS with Selet Plus
    Quote Originally Posted by BigChris View Post
    AWE FMIC
    AWE Exhaust
    Carbonio Intake
    Bosch Plugs
    Bailey DV
    Any ideas?
    if you go to the plumbing aisle at lowes, they have these plastic T fittings that are PERFECT. my podi didnt come with one (and a lot of things for that matter, but still love it). they come in a baggy of 10 or 15 for about 3 dollars.
    did your kit include exhaust mani, TP and TIP?
    Kyle
    2.0L Revo GTRS Eliminator
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Turn off your ESP and watch the car pull even harder.
    ESP retards timing and messes with the ABS. These bigger turbos play games with the ESP system. I've gotten into the habit of turning my ESP off whenever I start the car (can not be permanently turned off as far as I know).
    Have you logged timing advance and correction factors (CFs The amount, in degrees, the ECU retards timing from the pre-programmed advance.)? Is your ECU pulling back timing advance? If so then you might want to tweak the Select Plus settings. Less timing advance = less power.
    -Doug
    May 20 2007
    Bergen County NJ
    Quote Originally Posted by A4natomical View Post
    I'll definitely check out Lowes for the tee connectors....
    The kit came with the ATP manfiold (pain to put in). Forgive the noob but what's TP and TIP?
    1992 Mercedes 300SD
    2014 Audi Q7
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    TP-test pipe, exh. side
    TIP-turbo inlet pipe, intake side
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    May 20 2007
    Bergen County NJ
    I never knew that ESP had that affect!!!
    I have the VAG COM but haven't really logged much since I'm not too familiar with how the system works. I'm waiting for my buddy to get some free time to help. He does the work for me... I prefer to drive! Don't get me wrong though; I want to learn this stuff as well and have been doing alot of reading but I find it easier to work with someone who knows this stuff rather than trying (breaking) it on my own.
    1992 Mercedes 300SD
    2014 Audi Q7
    May 20 2007
    Bergen County NJ
    gotcha...
    Yes i do have the Samco inlet pipes and the Eurocode Tuning test pipe.
    1992 Mercedes 300SD
    2014 Audi Q7
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    ESP doesnt do SHIT for causing power loss unless there is a traction loss sensed and you will know this since the car will fall on its face and the esp light (the triangel in the dash) will start flashing, this will almost NEVER happen in a straight line, only if you try to get on it hard in a corner, say taking off from a redlight to then turn down a road. If that isnt happening then you are not losing power, I have no idea what dougyfresh is talking about.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Actually it does. If your MAF is reading more that 229 g/s the throttle body will close, if you turn off the ESP it will override this.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by A4 TSCHUSS View Post
    Once my 2.0 is installed and we retune I'll get you dyno numbers and logs with and without ESP if you so desire. It makes a big difference on my car. Not sure about a REVO-powered vehicle.
    -Doug
    Veteran Member Four Rings audikid66's Avatar
    Jun 13 2007
    Belmar,NJ
    esp being on with a maxed k04 setup the same effect? i kno if u are launching u defff hafta turn esp off but besides that is this tru with ko4?
    Current car: Stage 3+ 2002 Audi allroad 6 speed
    Past cars:
    imola b6 avant 5spd/URS4 avant Big turbo aan/B7 RS4/k04 b5 Avant /BAT B5 Rally car/B6 Ultrasport/TT / multiple B5 A4 /5 speed ford f-150
    Veteran Member Four Rings skeeball's Avatar
    Sep 20 2006
    Baltimore
    I can get ESP to kick in when taking off from a light without turning. It would screw up just about every launch if I didn't disable it.
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by skeeball View Post
    guess you didnt read where i said UNLESS THERE IS A TRACTION LOSS, which in the case of LAUNCHING from a light then there will be atleast a slight loss of traction or in my case all 4 tires spinning for several feet therefore causing ESP to activate.
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    Quote Originally Posted by 400HPA4 View Post
    how is the MAF going to read more than 229 what do you mean by that? the stock MAF maxes out at 229 g/s, but anyway im pretty sure he wasn't talking about someting like that, but I could be wrong.
    ~David~
    CTS-V 9.6@148
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    It maxes out at 229 g/s once it hits 229 g/s for an extended period of time (meaning you are actually drawing more then 229 g/s through the MAF) you will get throttle cut, my car does, especially in second gear under full throttle, to override this the ESP needs to be turned off.
    Apr 24 2005
    E55 AMG, CTS-V
    I always have ESP on, that is interesting because mine has never had throttle cut on a log
    ~David~
    CTS-V 9.6@148
    Active Member Three Rings 3thrd_a_4's Avatar
    Oct 15 2006
    03 BT A4/91 GTI 2.9VR6 S/C'd
    When my MAF maxes out the ESP light comes on until I let off the throttle for a bit. I also throw a code for the MAF upper limit exceeded. Is this the same thing?
    ReVO BT and a bunch of other stuff
    Sep 20 2006
    Baltimore
    I did read. You just phrased it really poorly. Read what you wrote. It says traction loss will almost never happen in a straight line.
    Just miscommunication, I guess.
    Apr 24 2005
    E55 AMG, CTS-V
    yes driving in a straight line you will not lose traction, but I would think that even an educated monkey would know LAUNCHING would be an acception since that isnt normal or even aggresive driving but dropping the hammer at high rpms, so yes of course something would happen in that case.
    ~David~
    CTS-V 9.6@148
    Sep 20 2006
    Baltimore
    Wow! I chalked it up to a miscommunication and then you call me a monkey? I'll stop posting in this thread now.
    Apr 24 2005
    E55 AMG, CTS-V
    I guess that was "miscommunication," because I didn't say you were one, I was saying you should have known what I was talking about, but whatever...
    ~David~
    CTS-V 9.6@148
