Results 1 to 4 of 4
    Veteran Member Four Rings .Mad Hatter.'s Avatar
    May 07 2007
    Control Arm Help!!!! Urgent
    hey guys, im doing my control arms right now and things were going fine...until i got to the bottom arms. how the hell do you get the bolt out that attaches the arm to the sub frame? its an 18mm nut/bolt, and the bolt goes right through the the sub frame. there is no room to work with...do i need 2 18mm wrenches to get these lower arms off?
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Re: Control Arm Help!!!! Urgent
    I think if you wiggle and angle enough you can get it out. We had this problem on my friend's car but I forget exactly how we did it. A quicker root I would think would be to drop the subframe a bit.
    the homebrew'd s4
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    I definitely needed two 18mm wrenches for mine. It should wriggle out with enough effort, possibly by jacking up the hub (or lowering it as the case may be) a bit. Turning the wheel left or right might help too. Worst case you can lower the subframe which is a bolt located nearby on the chassis that gives you a bit more wiggle room.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    May 07 2007
    its not the bolt side that we had trouble with, its the nut...its inside the subframe
    they werent worn, so i just left them, we replaced the uppers and the C arm at the bottom so at least the problem parts are replaced.
