Results 1 to 15 of 15
    Feb 24 2004
    Minneapolis
    No Signals and/or Hazards
    I've done a search but most people seem to lose the turns but not the hazards.
    When I turned the key yesterday, there was some click noise, and a red light came on through one of the buttons....I believe it was the hazard button....and the car wouldn't start. I thought it was a burglar alarm glitch where the car was disarmed. I locked the car, unlocked it and all was well, except now I have no turn sigs or hazards.
    All fuses are fine. Any ideas?
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: No Signals and/or Hazards
    Replace the hazard switch.
    Feb 27 2005
    North Wales, PA
    yup, hazard switch is dead.
    Feb 24 2004
    Minneapolis
    I just took it apart. Expected to see burn marks or something. Nothing.
    Established Member Two Rings klausc's Avatar
    Dec 17 2005
    2008 Outback, 2008 MB GL, 1967 220 Volvo
    Shorewood, MN
    The "new" hazard switches have a tighter spring than the originals. Both of the metal spring tabs on each side need to be bent with a pair of pliers before putting the switch back in the dash. If you don't do this, the switch will be very hard to insert into the slot, especially the last 1/4 inch, and you will find the hazard button will not depress.
    Klaus
    Klaus,
    2001 A4 2.8 Q and a 1967 122 Volvo wagon
    Feb 27 2005
    North Wales, PA
    Quote Originally Posted by mtroxel View Post
    probably a bad coil which you can't spot. Trust us, just replace it.
    Feb 24 2004
    Minneapolis
    OK, so I got my new flasher today, put it in. Hazard flasher still dead. Turned on the key to see if the blinkers worked. I heard a little "tic" noise. 10 amp fuse blew. This fuse did not blow when the problems started. The fuse was good when I put the flahser in. So I put in a new 10 amp fuse. No Hazard flasher. Turned the key, blew another fuse.
    So with a new flasher relay, I have no flashers. If I turn on the ignition, I make some sort of dead short that blows the fuse.
    Any idea?
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    If your flasher was dead your hazards would still work. I will say like everyone else said replace the hazard switch and go from there.
    Registered Member Two Rings NeubsA4's Avatar
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    x2. on all vehicles there are 2 separate flashers. One for the blinkers and the other for the hazards.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by GetAwayFromMe View Post
    That's what I replaced. The whole switch.
    NeubsA4, I don't know about any other flasher. Where is it and how would that make my dead short when I turn on the ignition?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    if you replaced the hazard switch and it did not fix the problem you've most likely have a short somwhere
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by AudiTechS4 View Post
    Yea I'm in Bentley right now trying to figure out the wiring.
    Veteran Member Three Rings audimuse's Avatar
    Aug 10 2007
    09 MB C63 AMG
    denver, co
    i'll save you time on this. get the turn signal switch (its costly and its the one on your steering column with the light switch) replace that and your hazard relay (its not a switch but a big fuse). i had my signals die completely and hazards still work, got my car back today and it is working better. i would have a someone like a dealer or someone who will cover it if the blow the airbag while replacing it.
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by audimuse View Post
    The only hazard relay I see is part of the switch. It's built right on to the back of the switch and I don't see what you're talking about (meaning a big fuse) in Bentley or anywhere else.
    I had thought of the turn signal switch in the stalk itself as you suggested. If there's a short in that, the current from the ignition would blow the fuse. But then why don't the flashers work with out the key turned?
    Jan 30 2008
    01.5 Audi A4 1.8t
    Buffalo, NY
    check to see if you are getting power to the hazard switch with an electrical voltage tester. Pain in the ass cause you have to do one wire at a time. I'm at work right now, lol otherwise i would be pulling out the chiltons manual. If it isnt the switch then its probably a short. thats the only way that the fuse would blow that i can think of? Usually if it is a flasher your blinkers will blink rapidly instead of not at all.
