Results 1 to 13 of 13
    Veteran Member Three Rings mrbogangles's Avatar
    Apr 06 2008
    ;p
    phoenix az, bay area
    wheel fitment need help b5 s4
    I got some bbs lm rep.
    18x8 and 18x9 with +38 offset
    i know i am going to haft to run some 5mm spacer up front to clear the calibers
    i am going to run 245 40 18 tires
    i am wondering if there is going to be any rubbing issues
    or if this wheel would clear
    its going to be on stock susp.
    Jun 14 2005
    Anaheim, CA
    Re: wheel fitment need help b5 s4
    I have no recommendations for the back, but for the front you should be running a 225/40/18 tire.
    -Charles@VMRWheels
    Brandon @ VMR Wheels
    Brandon@Velocitymotoring.com | 714.442.7916 Ext 108 | www.velocitymotoring.com| Instagram | | | Blog
    Apr 06 2008
    ;p
    ok thanks for the info
    ill try that out
    i just hope the rear would be ok cuz i already have the tires
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    245/45 looks a little tall to work safely.....
    Apr 06 2008
    ;p
    i am going to run 245 40 on the rear
    225 40 on front
    just worried about the rear
    i just hope it doesnt rub
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    Quote Originally Posted by mrbogangles View Post
    225 40 on front
    Do NOT mix and match tire sizes on a quattro.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Apr 06 2008
    ;p
    i got 18x9 for the rear front are 18x8
    would a 225 fit on a 9in wide wheel
    but since the rear wheels are wider shouldnt i get a wider tire
    like 225 in front and 235 in the rear
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    some 225's will clear 9 inches. youd have to look up the specs (tirerack.com has a good easy to read chart)
    as far as the staggered setup, you need to research the rolling diameters of each tire youre looking at and make sure theres less than a 4% difference in size otherwise you'll be burning up your center differential.
    Oct 16 2010
    DavidhogAJ
    https://t.me/pump_upp
    i got some bbs lm rep.
    soul caliber
    Veteran Member Four Rings LJH's Avatar
    Oct 03 2006
    '84 Ur-q, '04 S4 6MT, '08 Outback XT 5MT
    225 40 on front
    As other have mentioned that is a not a good idea at all. Audi's have a lot of weight bias forward so why would you want to put smaller tires on the front? Audi's are meant to have equal sized tires all around...and to combat under steer some tuners have actually used larger tires in the front.
    Not to mention but your choices are really limited getting a 225/40/18 with a load rating of 95 or better.
    If you want to run a staggered set up buy a Bimmer, Benz or a '76 Monte.
    Cheers,
    Jim
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by bondar1989 View Post
    soul caliber
    Holy irrelevant post thread revival, Batman!
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    saving thread
    Jun 14 2005
    Anaheim, CA
    Awesome.
