Results 1 to 3 of 3
    Apr 04 2008
    milford, pa
    osram silverstar
    The owners manual doesn't show how to replace headlight bulbs. I would like to replace low and high beam with osram silverstar bulbs. How do I replace, or are the standard OE bulbs white?
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: osram silverstar
    I'm guessing you have the Halogen lights and not Xenon. Right? you search and you should be able to find it. follow the directions to change the Xenon lights. it should be the same for Halogen minus the part of the high Voltage.
    Senior Member Three Rings rayiish's Avatar
    Feb 03 2008
    Brooklyn, NY
    In the user's manual, all it says is see mechanic to switch it out for you. this is because its not as easy as any old honda.. if you have an 08 or sline exterior. you could replace them by moving some stuff around. see the DIY section, there is a bulb change diy there. if you have a regular exterior then maybe someone else can help you because i had to remove my bumper for mine
    Ray
    2006 Audi 2.0T Quattro w/ Tiptronic -Dolphin gray | APR 93 | RS4 Rearsway bar | Tinted head lights/tail lights/side reflectors | Bulbs changed | Clear Corner
