Results 1 to 37 of 37
    Senior Member Two Rings apexslider's Avatar
    Jan 09 2008
    Oregon
    Went to the Dyno today
    1.8TQ GTRS elim kit equipped, South Bend clutch, apr exhaust, and pump gas....226awhp and 252tq at 25.3psi. I was hoping for more, but it knocked at higher boost so that's the best I could get. This was on a Mustang Dyno. As soon as I get my camera charged I'll try and post the graph
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Re: Went to the Dyno today
    Prolly would have had 20-30 more HP at 22psi (lower egts = more timing)
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    That seems a bit low. Like Greg said, lower the boost and increase the timing will yield more power.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Jan 09 2008
    Oregon
    our first run was at 21.7psi and we only got 220hp and 247tq. Either way, the numbers suck. I'm really disappointed
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Why is this?
    I plan to go GTRS...but it seems like dropping close to $3K just simply isnt worth it
    -Sami-
    Jan 09 2008
    Oregon
    that's my question. I'm going to do a leak down and compression test to see if that tells me anything. As of now I'm praying the motor has some issues becasue those numbers are NOT worth the 3200 I paid and the hassle Eurocode put me through
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    You can't just slap it on and expect #s like Gregs. I'm sure he set the boost and timing, logged, dynoed and then adusted, logged, dynoed, so on and so forth. They're not plug and play for max. power, you have the adjust the settings, more boost less timing, or more timing less boost, etc.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Feb 17 2005
    Sarasota, FL
    Thats for sure way low, good luck finding the issue!
    Veteran Member Three Rings converted2audi's Avatar
    Jan 21 2007
    B6 1.8T Quattro
    MI
    is that with the Revo BT file? Im getting ready to put the gtrs kit on my car in the next month or two.....have mostly everything i need! Have to do my timing belt first though....
    What are the rest of the components of your kit? FMIC? You said its the elim kit, so you are still running the oem manifold? Test pipe or hfc? Those things will all make a difference in your numbers too.....a straight eliminator kit isnt going to put up Greg's numbers.....
    She said its just a car...i said you're just a girl.
    Jan 09 2008
    Oregon
    I wasn't expecting anything close to greg's numbers...not sure where that came from. I was thinking 250awhp.
    I'm running REVO's BT file, atp's high flow stock manifold, 3" test pipe, awe fmic, and full exhaust. So it's not just the kit, there are some supporting mods to help.
    Dec 06 2007
    ^^ try using my VAC LEAK guide from my new post it has part #'s and everything!
    -Kirk
    BetaAlphaTau Member #58
    Mar 21 2006
    Lakeland, FL.
    Sounds like you need to play with the setting. Do you have a SPS and Vagcom?
    I'm back bitches!
    Jan 09 2008
    Oregon
    Quote Originally Posted by dirtybrd View Post
    I have access to both. I've got the SPS3 sitting in my glove box, but I'm not really understanding how it works. I've got a mbc so doesn't that leave the sps useless unless I'm changing to a higher octane file? As for vagcom, I need to learn how to log so I can get more detailed info posted, like those spread sheets I see.
    Mar 21 2006
    Lakeland, FL.
    Read how to set it and set your boost to 9 and your timing to 5 and see how it feels. When the ECUs are flashed I think they are set @ B6T3 which would explain you low numbers. You still want the ECU to see B9 even though you're using a MBC.
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    You should have seen 250AWHP easily. I will explain to you how the SPS works for you.
    There are two knobs on it with 10 settings each (0-9)
    If you are running a MBC or EBC you want the boost setting to be on "9", with this setting the ECM is requesting 2540 mBar of boost at all times. (Mode 3, Setting 9)
    It you are using pump gas (91-93 octane) you want to set the timing to 3-5. (Mode 5, Setting 3-5)
    If you were running 23-25 pounds of boost with the MBC and did not have the SPS 3 set to boost 9, you were killing your power, (the ECU was seeing overboost and was pulling timing like crazy)
    Here is a copy of the user guide for the SPS3 http://www.revotechnik.com/products/...Guide_V2.3.pdf
    Jan 09 2008
    Oregon
    that would explain a lot...I was reading the instructions in the box with the sps, but it wasn't to informative. I'll go out and change the settings and see what I think.
    Thanks again for the above, makes me feel much better.
    Mar 21 2006
    Lakeland, FL.
    Also don't forget to turn the boost down to about 20psi to start with. But you can't forget to run some logs. Just because it feels good doesn't mean its safe, that goes for cars and sex.
    I'm back bitches!
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by apexslider View Post
    Anytime you need help, feel free to ask...
    You may not notice the differnce when you are driving, unless you are in a high load situation, the ECM only pulls back the timing when it needs to.
    This is most likely what happened in your situation...ECM saw overboost based upong the MAP requested (Boost 6) and tried to close the throttle plate (this is overidden though) so it began to add fuel to keep the A/F safe and the EGT's wen through the roof. Once the EGT's were to high, it began pulling timing.
    The end result was less than the 250AWHP you should have seen.
    Three key rules for dynoing your car.
    1.) Fresh Plugs
    2.) Race Gas
    3.) Log the first pull, watch the A/F and Timing, be ready to abort mission if necessary.
    The dyno operators (Dicks) are usually in a hurry to get you on the dyno and get you off the dyno, haste makes waste, it is not their car they are damaging.
    You can bet your ass too that if you toss a rod, they will make YOU clean up the mess
    Sep 20 2006
    MD
    Yeah, I'd be disappointing too. On my base run with my 71R elim with only like 17 - 18 PSI (SPS settings: T2, B6), I put down like 243+ awhp. That's on a auto tranny AND stock cat
    Jan 21 2007
    B6 1.8T Quattro
    MI
    Quote Originally Posted by 400HPA4 View Post
    How much psi is the pre-set setting of boost 6 supposed to see?
    Jan 09 2008
    Oregon
    already done, turned it down to that for the last pull.
    Jan 09 2008
    Oregon
    thanks I'll try not to blow your inbox up
    Jan 09 2008
    Oregon
    [QUOTE=RLB6;2417488]Yeah, I'd be disappointing too. On my base run with my 71R elim with only like 17 - 18 PSI (SPS settings: T2, B6), I put down like 243+ awhp. That's on a auto tranny AND stock cat
    [QUOTE]
    thanks for rubbing it in
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by converted2audi View Post
    There is no exact "pre-setting" it is all based upon duty cycle and your wastegate if you are running the N75
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Have you ran on this dyno before or has anyone else you know run on it so you can compare your #'s to them? Because you cant compare your #'s to someone elses that ran on a different dyno.
    Quote Originally Posted by RLB6 View Post
    3125 lbs for a B6 1.8t quattro tiptronic and driver? How did you come up with that weight or was the driver a negative 500 lbs? You do know that putting in the wrong weight will mean the #'s the dyno plots out are going to be wrong?
    Stock 2002 B6 1.8t quattro tiptronic curb weight is 3550 lbs, so even with a avg person in the driver seat will be over 3700 lbs. So as you can see your 3125 is way off.
    Sep 20 2006
    MD
    This point was argued when it first happened and since I wasn't allowed back in the dynoroom, I was not able to correct this. It's spilled milk now.
    BTW, it wouldn't be that way off but you're right, it is off. Had the correct weight info be inputed, then my numbers would have been higher
    Veteran Member Four Rings Redgoat's Avatar
    Sep 16 2005
    So True my friend!
    -Karl
    NWQuattro - Northwest Audi Club
    USP CLUB MEMBER #8
    BetaAlphaTau member #10
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    You should never be running 25psi on pump gas first off, one thing people need to learn is more boost doesnt always mean more power. Having alot of boost and no timing isnt worth shit. And like the others have already informed you, turn that Boost to 9 with the sps then set the mbc accordingly. I would personally run the boost at 22psi and the timing at 5 and I guarantee you would have made 250whp unless your car has a problem.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Feb 29 2008
    Durham/NC/Southeast
    I am not at my dyno computer but I think the hp@50mph is wrong also. I don't remember seeing an Audi less then 10 ever especially a quattro. The specs come from Mustang. I will check mine tomorrow.
    Jan 09 2008
    Oregon
    Quote Originally Posted by A4 TSCHUSS View Post
    We went from 21psi to 25+ with a little tap of the mbc. That high of boost was not intentional. I'm fully aware of limits on pump gas. I used the sps today and it actually did crisp the power up some. I dont have my boost gauge yet but it should be around 20psi. I'll be able to keep better track once my podi gets here.
    I'm going back to the dyno here in the next week or so after we make some changes. I'm hoping for better numbers next time
    Apr 24 2005
    E55 AMG, CTS-V
    I had 13hp at 50mph on one dyno and at a different dyno (different facility) I had 12.7 on 2 different runs
    ~David~
    CTS-V 9.6@148
    Apr 24 2005
    E55 AMG, CTS-V
    do you have VAG COM? If so then go do a log in 3rd gear while logging block 115 and it will show you requested boost in 1st column then actual boost in the 2nd column. You will have to convert it from the BAR it is shown in to PSI after also subtracting 1000 from the number if you are at or near sea level.
    actual requested
    Ex. 2400 2350
    2350-1000=1350 or 1.35 bar which is 19 psi (google a bar to psi conversion table or calculator to find out the exact conversion). By doing what I just showed you, you can see exactly what you are running.
    ~David~
    CTS-V 9.6@148
    Feb 29 2008
    Durham/NC/Southeast
    Sorry i meant that is a number that the mustang company provides. the operator has to input it for each car. I would think 12.7 sounds better. I will try and look at the list tomorrow.
    Jan 09 2008
    Oregon
    actual requested
    Ex. 2400 2350
    good to know, great to know actually. I'll get some numbers and post up. Any one know a good "how to" guide for lemmiwinks?
    Feb 29 2008
    Durham/NC/Southeast
    the mustang dyno settings should be 12.7hp@50mph and 3875 for the weight.
    Mar 21 2006
    Lakeland, FL.
    You have PM
    I'm back bitches!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Evan@Absolute View Post
    Does that help set the rollers correctly? Which will affect the power/torque results.
    -Doug
