Results 1 to 8 of 8
    Veteran Member Four Rings agkellyboy's Avatar
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Angry Running Rough...Frustrating
    So about two weeks ago my car was feeling great. I took it out for a nice long run before I left on vacation and everything about the engine felt great. Now, I come back a week later and all of a sudden the motor seems to be running rougher than usual.
    The only engine mods I have are NGK copper plugs gapped at .032" put in ~1000 miles ago, and a cold air cone intake w/ heat shield. In addition to feeling rougher than normal, the car doesn't feel like it pulls as hard as it has in the past and third gear seems to take forever.
    At WOT, boost gauge reads a spike of 10 psi dipping and holding to about 9 psi. Mileage is only 2500. Any ideas?
    FS - Dolphin B7 A4 Ti 2.0T MT6 Quattro Project 400R
    Veteran Member Three Rings kill4surf's Avatar
    Apr 28 2004
    2021 Premium Plus e-Tron
    Re: Running Rough...Frustrating
    make sure the plugs are torqued properly. they can cause major damage to the cylinder heads after a while.
    21 Audi e-Tron
    23 Audi A4 S-Line Black Optic
    19 A5 S-Line Sportback GONE
    18 Q5 GONE
    15 A4 S-Line GONE
    09 A3 GONE
    07 A4 S-Line GONE
    03 A4 1.8t Revo Stage 2 GONE
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    After I felt something off, I took them all out, checked gap, and torqued all at 22 ft/lb
    Veteran Member Four Rings gods_kitchen's Avatar
    Are you chipped?
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Nope, stock ECU.
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    Bump, anyone?
    Oct 12 2005
    B7 A4 2.0T 6speed Sline
    San Francisco
    I suggest putting the stock plugs back in and stock airbox and see how it runs...if you still have issues take it to the dealer and let them deal with it.
    Feb 27 2007
    2010 S4
    Philly 2 Bmore
    I checked the plugs again and found an issue with one of them, torqued it back in and things seemed a whole lot smoother (or I'm a sucker for the placebo effect).
    Now, while I was listening to the engine, I leaned in on the PCV round cap and it was making some crazy rattling noise not in sync with the engine noise...is this normal?
    Finally, I think I'm going back to stock on my intake. The filter wasn't of the best quality, and while it's not oiled, I can't imagine that it's filtering out much. The sound is great, and I even would say it changed the power around a bit, but in the end I think things will go a lot smoother in the future if I keep it stock.
