Results 1 to 7 of 7
    Veteran Member Four Rings AudiOso's Avatar
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Is this normal for a Tiptronic?
    My Avant's transmission does a weird thing in 2nd and 3rd gear. More so in 3rd. If I am in Tip mode and in 3rd when I slow down to say go around a street corner if the revs drop below 2000 rpm, when I step back into it the revs go to about 3000 rpm or so then about a second later they drop to around 2200 rpm. Is this the torque converter locking up? It really is annoying.
    If the car is in drive or sport mode it is fine, but I prefer to drive it in Tip mode. Anyone else experience something like this and is this going to be expensive?
    A couple of Audi's later...
    "It's a false state of elation... You can join the Prozac nation... If you want to..." - Killing Joke
    Established Member Two Rings drmarcj's Avatar
    Feb 14 2008
    xxxx
    Re: Is this normal for a Tiptronic?
    Yes, sounds like it's the TC. If you have a vagcom, check the Ross-Tech Wiki where it talks about 'new' vs. 'old' tip strategy. Could be you can recode it to be more to your liking.
    03 A4 Avant 1.8T -- 17" B7 RS4 reps | Sirius Satellite Retrofit | '02 Sport Susp.
    03 Lexus RX 300 -- Wife's car, no mods allowed
    98 Passat 18.T -- Sold
    92 Golf GL -- Long gone
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    could be a TCC solenoid problem.... (tcc= torque converter clutch)
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Quote Originally Posted by eg6siR View Post
    yeah i get the same problem get around a corner in 2nd on tip and try to get back up gets to 3000k and drops to 2200 then goes back up steadily. I have yet to vagcom it to fix that.
    Aug 04 2007
    Do Hotwheels count?
    Boardman, OH
    Where do I find the Ross-Tech wiki?
    Dec 06 2007
    ^^ if u have APR 1+, then this is ur problem, it is the TC locking up, and can't be fixed mine does it everyone's does it with 1+, try reprogramming ur AT to 0000032
    -Kirk
    BetaAlphaTau Member #58
    Feb 14 2008
    xxxx
    Quote Originally Posted by AudiOso View Post
    Here's the linky-link. But it's not as helpful as I remembered. Try this instead.
