Results 1 to 22 of 22
    Veteran Member Three Rings ChumbaWumba's Avatar
    Jun 06 2007
    weird startup...watch video...need insight...just pulled new codes*
    has anybody had this problem before?...i need new EGT and front 02s...been clearing the codes for sometime...but it just started doing this recently...at first i thought it was my battery or alternator but they both checkd out good and so is the starter itself...so my main question is...are these problems directly related to either EGT or 02 sensor? or do i have a different problem ?(knock on wood)
    http://www.youtube.com/watch?v=9JUH7G4nrfU
    [shameless plug]
    IF YOU HAVENT DONATED CHECK OUT THE LINK TO THE THREAD IN MY SIG...ITS FOR A GOOD CAUSE!
    [end shameless plug]
    *UPDATE*
    i pulled codes off my car and got the same old egt and 02 sensor ones but these ones are new...
    18011.p1603 internal control module memory:checksum error
    16946.p0562 system voltage:low voltage
    if anybody has any ideas...let me know
    TIA
    jeffrey
    Dec 12 2007
    Boston
    Re: weird startup...watch video...need insight
    LOL... "somebody enlighten me"
    "it doesn't fuckin kick"
    my favorite parts along with the ignition double flick...
    wow, i am clueless. I was going to say CTS, but if it works fine after that double flick action ,i dont knwo??
    maybe someone else can enlighten you
    2001 S4
    Stage 3 totaled...
    new- 2001.5 Nogaro
    Jun 06 2007
    Quote Originally Posted by sweed View Post
    lol...there was a video i made before this one...but it didnt do wat i spent like a whole minute explaining wat the problem was...n i was just like "wat the fuck i swear im not crazy...it just decided to correct itself as soon as the camera showed up"
    Veteran Member Three Rings SilverSurferS4's Avatar
    Jun 11 2007
    maybe its the ignition swtich...
    Veteran Member Three Rings b5s4tt's Avatar
    Mar 14 2007
    s4
    queens
    i gotta think but that a nice anti theft device
    Dec 06 2007
    Calgary, AB, Canada
    Definitely not related to a bad EGT or O2 sensor.
    I would also suggest replacing the ignition switch. It's like $20. Takes 10 minutes and is worth a try.
    Jun 06 2007
    Quote Originally Posted by b5s4tt View Post
    or anti-drive device
    Quote Originally Posted by The_Jerbel View Post
    where is this ignition switch u speak of located?
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    Ignition switch is the thing the key goes in. Seems like a good place to start based on what you know.
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Dec 06 2007
    Calgary, AB, Canada
    There are 2 parts to it, the electrical portion and the lock cylinder portion.
    You need to remove the steering wheel. Remove the trim surrounding the steering column. And then you should see the ignition switch. Scrape off the red paint from the two screws holding the electrical part in place, disconnect the connector, and replace the switch.
    Jun 06 2007
    Re: weird startup...watch video...need insight...just pulled new codes*
    today while driving...my car kinda cut off...then turned back on??? while in motion...this is like the 3rd time it has happened...maybe a faulty connectionof the ignition switch...i dont know..
    *UPDATE*
    if anybody has any ideas...let me know...
    also...the wrist flick is starting not to work =/
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    My bet is on the ignition switch as Jerbal said. Seams easy to replace. or even just loose connections with the switch, especially if you are able to flick the switch a couple of times to get it to work.
    Your pixels in your center speedometer look great. Mine only miss a few sometimes but come back after driving for a time, but yours looks perfect!!!
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Jun 06 2007
    Quote Originally Posted by gointoscott View Post
    damnit dont jinx me...lol...im hopin they will stay perfect after i replace my brake pads...that symbol has been on there for some time...lol
    how do i start to take apart the steering wheel? i was looking at it today...and couldnt figure out where to start...ive done my downpipes and exhuast myself...i figure this shouldnt be that hard if somebody cant point me in the right direction...in other words...show me the door and ill be the one to open it
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yeah replace the ignition switch , its pretty easy to do . also that checksum error is not a good one.usually its the control module its stored in taking a shit.i would replace that ignition switch(the electric part) as soon as possible you dont want the flickering of the voltage to be hitting the ecu like that
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    I searched the p1603 code in my Bentley and one of the results was:
    Readiness code, generating
    Requirements
    -The respective fuses of the Motronic fuel injection and ignition system must be OK: Electrical Wiring Diagrams, Troubleshooting & Component Locations
    -Battery voltage must be at least 11.5 volts.
    -All electrical consumers like, for example, lights and rear window heating must be switched off.
    -If vehicle is equipped with an A/C system, it must be switched off.
    -Ground (GND) connections between engine and chassis must be OK.
    -There must not be any DTCs stored in DTC memory => page AUDI-B5-FU11-ST-002-05ST-23
    -Intake air temperature 5 to 35 ° C => AUDI-B5-FU11-ST-002-03ST-16
    -Throttle valve angle 12.0 to 16.0% => AUDI-B5-FU11-ST-002-03ST-16
    You said you checked the alternator, battery, and stater so I guess the ignition switch is all that's left in that loop
    770r B5S4 home built & tuned
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    1.back of steering wheel there are 2 holes- there are 2 t30 torx screws in there holding on your air bag.then there are a couple connectors.
    2.disconnect the battery before removing connectors-
    3.remove connectors and the center bolt to the steering wheel (i believe its a #12 triple square)-
    4.before removing the steering wheel mark it some how where the center bolt came out(score the metal on wheel and shaft)to ensure its straight on as before-
    5.remove the trim aroung the steering colunm(cant remember the little screws if they are a philips or a t8 screw)
    6.scrap paint off the the 2 flat head screws holding in the ignition switch (on the left with a plug going onto the end of it with some decent gauge wires)
    7.replace and follow in reverse order.
    8. connect battery when all is done and turn key on from passenger side just in case the airbag decided to be a dick
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    Quote Originally Posted by Matt Danger View Post
    thats just for setting readiness not for the fault code.
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Quote Originally Posted by ChumbaWumba View Post
    If you want to get rid of that brake light before you replace your brake pads, just take off the front wheels and look for the wire that goes to the brake pads and cut the wire and connect the two wires together and be sure and put black tape over the bare wire, this of course is just a quick fix until you get new pads installed.
    how it works is the wire is built into the pads and keep a connection, but as they wear eventually it wears past the wire and leaves an open circuit which prompts the light in the dash, once the connection is complete again the light goes out.
    But if you dont mind seeing that stupid light in your face every day, then it can wait too.
    I used to have a few lights on and they drove me crazy, so glad I got that taken care of.
    Jun 06 2007
    Quote Originally Posted by AudiTechS4 View Post
    OMFG are u serious?!?
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    I dont know for sure, but im pretty sure there is no way the air bag will go off if you do this. the only thing that can happen is if you disconnect the airbag while battery is plugged in, it could trip the airbag light to stay on all the time and have to be reset.
    So it is very important to be sure and have battery disconnected before you start taking steering wheel off. and then connect it after you put it back on.
    Ive had the steering wheel off on my audi's many times and havnt had a problem so dont be nervous about it going off.
    Biggest thing is to have the right torx for taking wheel off, not everyone has those in their tool box, and the other very important thing is mark where the steering wheel goes like they say in the instructions, otherwise when you drive down the road it will not be center and you dont want to have to take it apart again.
    if you did that other work on your car yourself, you can do this. Piece of cake!!!
    Jun 06 2007
    swizzee....thanks a lot everybody...imma prolly tackle this this weekend...
    Dec 06 2007
    Calgary, AB, Canada
    Well, I'd rather be sitting in the passenger seat that try and play chicken with the airbag in case there is some sort of short in the wiring and it blows...
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    yeah i my self have taken off over 100 steering wheels and have never had a problem most times i never even disconnect the battery but i have heard of a few cases that make me always sit in the passanger seat when turning on the key
