Results 1 to 22 of 22
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    So I'm trying to install my test pipe
    Sure sound good and all, but how the hell do you get to the rear flange bolts? I've got air tools up the ass but no way of getting to the bolts. Any ideas?
    --Black 2001.5 -S4- 10secS4 Tuned
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: So I'm trying to install my test pipe
    you have to get under the car with a swivel extension
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    doesnt seem like theres room with my air ratchet. tried a swivel extension.
    Jun 04 2007
    Austin/DFW, TX
    1. PB blast everything. Remove intake and your heatshield, and the first 02 sensor with a 7/8" wrench
    2. Remove the 2 Cat-Turbo bolts with a 17mm socket with swivel and extension.
    3.Remove belly pan, and then remove the bolt holding the downpipe to the car with a 1/2" socket.
    4. Remove the last Cat-Turbo bolt from the bottom with the 17mm socket and swivel and extension.
    5. Once you have the Cat loose from the turbo, pull the Cat off the turbo.
    6. There will be 3 bolts holding the Downpipe-Cat. Remove these 3 with a 13mm socket. They will be very hard to remove, dont worry about breaking them in the process because they are seized. (I broke 2 yesterday). PS:you WILL need a longgg ass extension with the swivel, this is the most frustrating part.
    7. After all those are off, the cat is free. Remove the second 02 sensor with a 7/8" wrench.
    8. Install is the same vice versa. any more questions, LMK
    My 5-Speed Swap DIY
    - B6 USP
    Apr 05 2005
    Casa Stg 3 S4
    evergreen state
    lol i didnt want to suffer this so i paid a shop to do it.
    Past (in order): Hibiscus Red B5 A4 ,2003 Audi RS6, B6 s4, UrQuattro, Urs4, Nogaro sport B5 S4 avant, Silver stg 3 B5 s4, 2010 A6 Avant prestige
    Present: Casablance White stg 3 B5 S4 avant, 2002 Audi S6
    Jun 04 2007
    Austin/DFW, TX
    Its really not so bad, I did it yesterday in about an hour and thirty mintues.
    The hard part is just getting those seized bolts unbolted, and having to put that swivel attatched to the socket back on the bolt continuously
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings VOoDooGTX's Avatar
    Mar 07 2007
    1987 Porsche 944 Turbo
    New Paltz, NY
    I used a air gun with a swivel extension. only bitch was the exhaust didnt want to come apart.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    the way i did it was to pull the downpipe and cat out through the engine bay(kinda a pia) and then put the downpipe on the tespipe and install in reverse.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Three Rings ////D's Avatar
    Aug 22 2007
    847 IL
    Quote Originally Posted by t1demont1 View Post
    thats what i did, and it worked well
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Quote Originally Posted by biketsai View Post
    you did it on jack stands?
    GIAC-X, STASIS TS,VAST,034 MS
    Jun 04 2007
    Austin/DFW, TX
    1st time I did it on a friends car we did it with jacks and it took some time. When I did it yesterday on my car I did it on a lift
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Lift reduces work time tenfold. Jack stand method is usually few hours with seized bolts.
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Quote Originally Posted by nebone22 View Post
    well find out tomorrow , i PB blasted the bolts overnight and tomorrow im hitting them with with a high torque impact wrench. screw hand tools
    Jun 04 2007
    Austin/DFW, TX
    Yea, i am very glad I was able to use a lift.
    It is the biggest pain trying to get leverage on a seized bolt when the car is about a foot off the ground
    My 5-Speed Swap DIY
    - B6 USP
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by Grangalan View Post
    MAKE SURE, that you get the bottom DP to Cat bolts, all three
    My 5-Speed Swap DIY
    - B6 USP
    Registered Member Two Rings _audible_'s Avatar
    Apr 19 2007
    A4 and a S13...
    VA
    If you haven't gotten it out yet, take your dp out with the cat still in place and swap them.
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    been storming all day so i gotta wait. To take out the downpipe is it easier than acessing the bolts?
    Jun 04 2007
    Austin/DFW, TX
    Jw, where does the DP disconnect? I dont have bolts to undo mine because I had that area cut off.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Teehee. It was fun tho.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    i have no choice in that. So i guess seized bolt, say hello to impact wrench.
    Just for the record, its easier to just take the TP off right? ill have 2 hours of sunlight to do this in.
    Jan 21 2005
    sf bay area
    IME there's no magic - just a lotta swearing / bashed knuckles with about 4 different swivels, extensions, etc.
    next time i do it i'm getting a set of flex-head gearwrenches at HomeD - those would make it a LOT easier. well.. maybe a little easier anyway.
    i think i pulled the tranny mount to get some clearance. i had a helper too holding the topside nuts while I worked the bolts. or vice versa. an extra pair of hands makes all the difference, if your TP doesn't have the captive nuts like the stock cat.
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    uhhh i will pay someone to do this shit for me, even with a swivel extension the only thing that will fit is a fucking crescent wrench ... and i dont have the room
    car is jacked up, no lift is acessible. this is BS
