Results 1 to 21 of 21
    Veteran Member Four Rings andru1313's Avatar
    Apr 13 2007
    Audi 2018 RS3 2006 Evo IX MR
    Frisco, Texas
    Shake Shake Shake.. My Front end Shakes
    Ok... I finally got rid of my crap wheels that were the wrong offset and causing me issues. I went back to Stock B5 S4 rims. Now I am really noticing the front end shacking and there is a wobble when i hit a bump. Like quick shake in the steering wheel different than if the car is out of alignment. I did check and the drivers side upper tie rod boot is worn away. But i think it is more than just a bad tie rod. I was thinking of buying this complete set but really don't want to spend the money. Dealer wants 444 bucks just to do the one side tie rod. Umm F that. here is the kit i am looking at http://www.purems.com/products/product.php/II=1869
    Do you guys think this will solve most of the issue? I run a Stasis Street Set up
    The front end just doesn't feel very solid. Also how hard is this to install myself? Thanks
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Shake Shake Shake.. My Front end Shakes
    Suspension work is as easy as it gets. You should be able to install that with a jack and hand tools. $444 for a tie rod is a rip.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 13 2007
    Frisco, Texas
    Quote Originally Posted by RolledMySTi View Post
    yah no kiddin. then another 150 for an alignment. Fthat. So do you think that this kit will solve my issue. I have done a ton of suspension installs on VW's Looks easier on the audi. But never did it. Is this kit worth 660 bucks?
    Dec 06 2007
    Calgary, AB, Canada
    Is the clunk in the steering wheel or do you feel it under your feet?
    Apr 13 2007
    Frisco, Texas
    Steering wheel and bad.
    Dec 06 2007
    Calgary, AB, Canada
    Steering related. Probably tie rod end that's really toast, or perhaps something more severe, like rack problems.
    Jul 06 2007
    San Jose, CA
    Tie rods are a common problem. I know I have had to replace mine. Check and see if the rubber on them is torn.
    Apr 13 2007
    Frisco, Texas
    Yah like I said in the OP driver side is completely torn away.
    Dec 06 2007
    Calgary, AB, Canada
    Replace it then and see if the problem is resolved.
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    rubber boot being ripped doesnt not determine if a tie rod is bad.
    jack up the front end of the vehicle. shake the wheel left to right, up and down. if you feel play, inspect accordingly while someone shakes the wheel to determine what is bad.
    typically:
    left/right = tie rod (inner or outer)
    up/down = ball joint (upper or lower)
    both = wheel bearing
    Apr 13 2007
    Frisco, Texas
    Ok thanks if it wasn't raining i would have it up on a jack but i don't have a garage so no go. guess it is going to have to wait a bit.
    Dec 06 2007
    Calgary, AB, Canada
    True, but if the boot is torn you'll have to replace the tie rod end eventually anyways.
    Quote Originally Posted by XJinCT View Post
    typically:
    Apr 13 2007
    Frisco, Texas
    Ok I replaced my tie rod ends. I still am having issues. My front end still shakes. When I hit 80 mph and above front end shakes as well as when i hit a bump. Now I know my upper control arm bushings are starting to wear. but i am also noticing when it is warm out when i turn the wheel it makes a bit of noise she turning it not from the pump but kinda sound like the steering column. I am getting so fed up with this car. Any one have any suggestions? I don't want to replace my control arms to find out its the steering column.
    Apr 13 2007
    Frisco, Texas
    TTT anyone? i am also hearing a rattle when I hit a bump.. sounds like from under the car... from the front.
    Established Member Two Rings stevea6/z28's Avatar
    Jul 29 2007
    01a62.7t,2z28's,71exercisebike
    conn
    possible ball joint also.Like said check on jack for side to side and up and down.Are your tires balanced?Just trying to think of all the basics.
    Apr 13 2007
    Frisco, Texas
    Ok I am just thinking of taking the plunge and ripping the car apart. I am pretty broke right now so want to make the best use of my cash. I was going to save some money by just replacing the bushings on the upper control arms.
    any thought on this procedure? I did this on my R32 on the rear control arms and it was a major pain in the ballz. but if I can save myself 400 bucks or so Its worth it. Post up your thoughts on this thanks.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Use the ebay, kit. Alot of people are happy with the quality + its only 300-400 for a full kit.
    l gotta-- l gotta get
    a form from a scientist.
    Registered Member Two Rings
    Mar 23 2008
    seattle
    If I were you, id go have the tires balanced and check'd for bends. 80+ sounds like a balance issue or minor bend in the wheel you wouldn't feel tell higher MPH.
    Apr 13 2007
    Frisco, Texas
    Quote Originally Posted by s4quattro187 View Post
    Yes I am going to do that but it still doesn't solve the shake issue when i hit a bump. I just know something doesn't feel right up there. super sloppy
    Established Member Two Rings dc878mmm's Avatar
    Jun 20 2007
    San Francisco
    I'm guessing your car didn't do that before you put the aftermarket wheels with the bad offset on. Since its unlikely that your stock wheels were bent during storage, its gotta be the suspension.
    2001.5 B5 S4 Stage 3
    Dec 06 2007
    Calgary, AB, Canada
    Did you get an alignment and have the bump steer set?
