Results 1 to 9 of 9
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    RS4 Cats on K04 S4
    since i live in belgium and we have to go to a car inspection facility every damn year where the car is being tested for springs, shocks, steering,brakes ,emission and so on...
    i was wonderin since i wanted to go stage 3 but i want to pass the test, meaning i need Cats, they have to have original audi emblems,diameter and the CO can not be more then listed. or else i have to change them every year
    a B5 RS4 got bigger cats and diamter downpipes then a B5 and makes 380 bhp so for a stage 3 like i want it, let's say 380-400hp it would be grate my guess???
    but is it and will it just fit and let enough flow on the stage 3?
    i'm just not in it for working on the car for hours or days every year to pass the test, we can't do bigger brakes,or lower the car without special fitting papers and special papers from the distributor so i have to do everything a little less then you guys , if they pic me off the streat and take me to a inspection immediatly (wich happens sometimes if you get busted streetracing or whatsoever) i want to be legal, cat-back is not so bad, bigger turbos and IC's and remap they won't see so i can do stage 3 but with things the eye does not see immediatly when lookin under the car and opening the hood...
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: RS4 Cats on K04 S4
    I'm sure they will work but the price will probably be killer
    - Clint
    Feb 20 2008
    belgium
    here in europe you can find them regularly on ebay for nice prices
    Feb 20 2008
    belgium
    is it bad to run k04's with stock cats for the life of the turbo?
    i know it will flow less but is the difference extreme?
    it's because i'm in the same shit here in belgium, every year the inspection where youre car is being checked completely for exhaust, brakes,emission test and so on...
    we can have mods like turbos,ic's and stuff , they won't see that and it doesn't matter if the car makes 400bhp as long as the CO output is ok!
    Feb 20 2008
    belgium
    no one?
    Active Member Four Rings
    Dec 11 2006
    Boston
    why dont you just buy a hi flow aftermarket cat?
    it will allow you to pass emissions and still have some fair gains in performance.
    Stage 3+ RS6's
    Veteran Member Four Rings S4Per's Avatar
    Feb 17 2004
    2013 Audi S6
    Quote Originally Posted by deb38 View Post
    because:
    ...they have to have original audi emblems,diameter and the CO can not be more then listed...
    2013 Addict::S6 (Build) // UNITED MOTORSPORT by AMD STG III | Milltek DP's and Valvesonic exhaust | 200 CPSI custom cats | AWE intake | Arc's, Helix, Morel's for sound
    2018 Q7 3.0T Prestige | Glacier White Metallic | Titanium Black Optic | Adaptive chassis | Drivers Assistance | Tow | Cold Weather
    Never forgotten:
    2008 Addict::RS4 (Build)
    2002 S4 Stage 3 Tip
    Feb 20 2008
    belgium
    it has to look like an original audi part
    but if it has NO emblems on it and it's not 3inch piping it would work maybe...
    wich brand sells unmarked 2.5 inch dp's and cat?
    and aftermarket cat's that flow enough will still pass emission tests?
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    Mar 26 2007
    2001 S4, 1999.5 A4
    Chambersburg
    Your stock cats will flow plenty good for what you want. The stock Audi cat is of high quality, and an aftermarket may or may not be such good quality, and even though it claims "high flow", it may not be. Until you are looking for the last 5 horsepower from your setup, don't worry about different cats...
    The single most important thing, and most worth spending $ on, AFTER going Stage 3, would be your fueling and tuning. Your gains there can far exceed the difference between RS4, S4 and aftermarket cats.
