Results 1 to 7 of 7
    Registered Member Two Rings
    Apr 02 2008
    How much on a TIP tranny
    How much power can they handle before they start to have problems??
    i know this has probably been dicussed a million times before but im a newb and cant find anything on it, although a friend at the dealership told me probably around 300hp and 280ftlbs??
    i have no idea if this is true or not
    Forum Moderator Four Rings blacka4's Avatar
    Dodge RAM 1500
    Pittsburgh Area
    Re: How much on a TIP tranny
    assuming you have a B6 310Nm is the max input tq which is about 228ft lbs. Not very much. I have heard of guys running more tq with upgrading the line pressure for the transmission but prolonged usage like that will greatly diminish the life of the trans
    -Rob - Moderator - PM Me!
    RIP:1999.5 Audi A4 1.8TQ Tip Brillant Black
    2009 Dodge RAM 1500 Crew Cab Sport - AZ Plate Frame - Bone Stock otherwise
    2014 Jeep Grand Cherokee Summit
    Veteran Member Three Rings eg6siR's Avatar
    Feb 06 2008
    1993 honda civic Si, 2004 Audi
    pittsburgh pistolvania
    Quote Originally Posted by blacka4 View Post
    yea, boosting line pressure will help for a limited time, then it will fail... if you only wanted to use it for a limited time, then rebuild it every couple weeks like drag racing guys do with there cars you could boost line pressure and run the hell out of it with a BT, but thats probably not an option for you, as probably like most of us, this is your daily driver
    snailspeed.net
    04 1.8t 6spd dolphin grey
    "you can go fast cheap but it wont be perfect, or you can build it right and go fast, but it wont be cheap"
    Apr 02 2008
    thanks for the info
    i dont have the car yet im still a couple of months away from purchase
    but i would just like to know facts so i can make a well imformed choice
    but yes it will be my daily driver
    Feb 06 2008
    if you havnt bought the car yet, buy a 6-spd, and if you can drive stick yet, you still have a few monthes to learn!!
    snailspeed.net
    Apr 02 2008
    yea i can drive stick but
    i do a lot of just cruising around
    and my current civic is a stick
    and i dont like cruising with a stick and in stop and go traffic
    its just annoying
    Feb 06 2008
    i know what you mean but driving my a4 is so much easier on the daily then driving my civic, both are manual trans. i almost bought an auto for convenience but decided not to after test driving the 6spd
    snailspeed.net
