Results 1 to 10 of 10
Thread: air filter
    Mar 12 2008
    CHI-TOWN
    air filter
    so yea runnning the stock wir box right now and was wondering is the k&n filter worht the extra 50 bucks or should igo with the ganeric ones for like 20
    Veteran Member Four Rings Smitty2A4's Avatar
    May 30 2007
    Stage 3 B5 S4 6 Speed l B6 A4 3.0 6 Speed (RIP)
    Boston, MA
    Re: air filter
    I have to replace mine soon too and am wondering the same. I know that K&N's are reusable so that may be a factor, but I am also somewhat worried about the over oiling issues. Although I had a FIPK on my old Jeep and never had an issue with it, although I only cleaned it once, but there was never any oil in the tube, but it was also a 95 and did not have a MAF.
    Looking for a good shop north of Boston, call Eurosport Performance
    Buncha motorcycles
    Memphis, TN
    Re: air filter
    OEM is fine, if you do K&N make sure you LIGHTLY oil it then let it sit in the sun a few days to thoroughly dry... quite a few people have had MAFs go bad from extra oil from the K&N filter...
    MAF=$$$
    APR Stage 2/AWE Intake
    Dec 06 2007
    Re: air filter
    i have one with 20k on it that i recently cleaned and oiled sitting around if someone wants it, it did wonders for me! i'll sell it for $30 shipped!
    -Kirk
    BetaAlphaTau Member #58
    May 24 2007
    Southern California
    Re: air filter
    yes. get it. the dealer even has a little display in the parts dept.
    showing how much more flow is allowed through it over stock.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    Re: air filter
    GO GREEN! i work at a parts store and refuse to buy any new k&n product. they have shipped us filters with the rubber not even covering the sides of the filter. K&N has lots of problems with quality control since they out branched. i have yet to see a green filter come in a severly messed up as the k&n's weve gotten.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    May 21 2007
    Florida
    Re: air filter
    i got one with about 7-8k on it, ill sell it to you for $35 shipped if ya want it. took it out and put on a cone filter/heatshield.
    2018 Navarro Blue Q5
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Re: air filter
    I have a new K&N for a B5 for cheap if anyone wants it (I'm an idiot and bought the wrong one...).
    -Darrick
    Registered Member Three Rings
    Aug 06 2007
    02 Audi A4 1.8T Q Tip
    New Jersey, USA
    Re: air filter
    Oct 31 2006
    San Antonio, TX
    Re: air filter
    In my past life I used to design air induction systems for cars. Yes the K&N has slightly better flow characteristics, BUT the losses due to the flow through the filter are so low that you really don't realize much performance improvement. IMO most of the perceived performance is the owner wanting to see improved performance to justify the $50 just spent on an air filter.
    Another thing regarding air filters, most people can use the same filter for at least 50k. Filters are designed to hold a lot of dust and fact of the matter is the roads in the US are very clean. Unless you're driving dirt roads on a daily basis, you probably don't need to replace it as often as the dealer suggests. Actually we found that changing the filter that often is worse for dust ingestion for 2 reasons
    1) The efficienty at which the filter capturs dust increases as the filter gets dirty. If you constantly change your air filter, it's effieciency is less than optimal.
    2) When you open the air box and pull the filter out, dust shakes loose and gets into the airbox. When the car is started back up that dust is sucked into the engine.
    You can actually increase the life of the air filter by pulling it out once it's dirty and gently blowing compressed air on it from the clean side. This will blow out a lot of the dust collected by the filter. Couple of comments on this; Do NOT use a high flow rate because you will tear the filter. Also, make sure you are blowing from the clean side (MAFS side of the filter) to the dirty side to dislodge the dust particles, else you'll just be blowing them into the filter. Lastly, do this AWAY from your car so as to not get dust in the air box while it's open.
    Hope this helps.
    Current: 2016 S6 Previous: 2015 A6, 2012 Q7 Prestige SLine, 2005 S4, 2007 Avant 2.0T, 2002 A4 1.8T
