Results 1 to 40 of 44
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    My dyno sheets from the March 31 dyno day
    I took the car to the dyno and my guys decided to stop the runs as they didn't like what they were hearing and seeing excessive venting from the catch can.
    Limped the wagon back to the shop and they did a leakdown test the next day and here are the results I was handed
    cyl 1 75%
    cyl 2 80%
    cyl 3 80%
    cyl 4 30%
    So the rattling noise I was getting boosting to 26psi was not from the chain cam or the lifters, it was from the exhaust valves that got bent/burnt/damaged
    Here are the dyno results from the couple of runs that were done. Not bad considering I was pretty much running on 3 cylinders.
    I'll be replacing all of the valves, springs and retainers with Supertech parts, retune and go back to the dyno again.
    Senior Member Two Rings apexslider's Avatar
    Jan 09 2008
    Oregon
    Re: My dyno sheets from the March 31 dyno day
    ouch. Sorry to hear that, I'm eager to see the "real" numbers. Whats the ETA on getting back to the dyno?
    Veteran Member Four Rings Tgr_Clw's Avatar
    Jul 20 2005
    2003 Audi A4 1.8TQM
    Toronto, Canada
    You know if you disable one more cylinder I think I'll beat you.
    Good luck Winston and sorry to hear about your troubles.
    Appearance: OEM+
    Interior: B6 S4 Recaro Seats
    Performance: MTM Stage 3 / Milltek Exhaust+Milltek HFC / JJ TIP / ASP FMIC / SB FE SS
    Suspension: Vogtland Coilovers / HSport S4 Sways
    Braking: Stoptech 332 BBK
    Wheels/Tires: BBS CH 18x8.5, ET35 / GY Eagle F1 GSD3 235/40/18
    Jun 11 2005
    Vancouver, BC
    Yeah... kind of sucks I keep breaking OEM parts but I don't think any of them were meant to take 2-2.5x the power output from the engine.
    The valves, springs and retainers are the only OEM pieces left in the engine and I could have taken heed to the warnings that I should upgrade the springs and exhaust valves but I thought I would be fine and wouldn't float a valve.
    So everything has come full circle. Car went to Blitzkrieg to replace the head 6 months ago and I decide to do a BT upgrade... 6 months later the car is back at the shop due to head problems
    But I'm itching to get this part done so I can go back and see what this machine can do.
    Jan 09 2008
    Oregon
    What kind of numbers are you hoping for?
    Jun 11 2005
    Vancouver, BC
    On a DynoDynamics unit? I would be happy with 320awhp and jumping up and down if I hit 350awhp at 26+psi
    Jan 09 2008
    Oregon
    whats that convert to on a Dyno Jet? Is that on pump gas?
    Veteran Member Four Rings A4TUNE's Avatar
    Sep 14 2006
    Mass
    do you have base runs on a dyno dynamics? the numbers are nice to see but aren't very accurate(maybe not the right word..) without base runs.
    -Max
    2004 A4 1.8T M6 Quattro Ultrasport
    REVO Stage 1 | AWE Boost Gauge | Carbonio CAI | Valeo Single Xenon Black Ecodes | RS4 Rear Sway Bar | 18x8 OZ Superleggera | DTH USP Splitter
    Jun 11 2005
    Vancouver, BC
    I have had all my dyno pulls on the same machine albeit different atmospheric conditions.
    Here is my K04 chart. Note that I made more power with a busted engine and a BAT
    blue - k04 + intercooler
    red - stage 1+ intercooler
    violet - stage 1+
    Registered Member Two Rings 986Jim's Avatar
    Feb 21 2008
    04 S4, 03 350Z
    Aurora, Ontario
    The best info I can find shows the K04 will only do 30-32lbs per min. Thats about 420cfm which is just enough for 250-280hp. With such a small turbo how are you going to hit 300-350hp even running 26psi which is way past the turbos efficiency? This is based only on looking at the compressor map for a K04 and the overall efficiency which is to say not very good.
    Do you have a hybrid or somehow otherwise modified K04? I do a lot of turbo stuff and racing but not much with the K04 so if I'm missing something here fill me in. Have guys made 350whp before on a K04?
    My talon with a T3/T4 50trim which is 49lbs/min which is just over 600cfm good for roughly 400hp. (average 150cfm per 100hp) and with 22psi of boost on the stock motor I made 323whp. With 26psi I made 357whp. I built the motor and upped the compression to 9:1 from 8.5:1 and ported the head with some Comp Cams and ran the same 26psi to make 424whp. I was right at the end of the turbo efficiency however. The 50trim is almost double the size of a K04 and I struggled to hit 400whp with it on a 2.0L motor which is known to make massive HP easily. A 60-1 fixed all that however (60lbs/min 750cfm )
    Regards,
    [edit]I am not trying to be rude or argue do not take it that way, I'm interested and am just honestly asking for some clarification because you seem to know what your talking about, thats all!
    04 S4 V8 Black on Black, Daily Driver
    03 350Z Performance edition. (272whp N/A)
    Mar 27 2005
    The Cold North
    Quote Originally Posted by 986Jim View Post
    Regards,
    I think you may have missed the part where he is No Longer using a K04, But running a GT3076 instead.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Feb 21 2008
    04 S4, 03 350Z
    Aurora, Ontario
    Nevermind I see you have a GT3076.. Ok, that will do it! Thats basically a 56trim that will pump over 50 lbs/min. You should hit 350whp with that fairly easily. I see you are running only 550cc injectors, you will be getting close to your duty cycle with those. To make 350whp I had 660 and later on 750s. I would bump your base pressure up quite a bit to maximize those 550cc's say to 45psi base, that will give you some extra head room up top.
    I'm anxious to see your results...
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Your car is to powerful winston...dyno dynamics are heartbreaker dynos
    Some fast things and some slow things
    ~Josh~
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by [email protected] View Post
    cyl 1 75%
    cyl 2 80%
    cyl 3 80%
    cyl 4 30%
    Holy shit. I've never seen leakage numbers that big. That sucks. Do you think you'll get to snap some photos of the head pre-disassembly? I'd like to see those valves.
    -Doug
    Jun 11 2005
    Vancouver, BC
    I think they gave me the results backwards as cylinder 4 was only holding 30% (leaking 70%) and that where they think the bent valve is.
    So the results 'should' be this:
    cyl 1 25%
    cyl 2 20%
    cyl 3 20%
    cyl 4 70%
    Still not great results and when I asked what proper percentages would be they said 97% (hold) or 3% (leak)
    I'll see if I can get in there with a camera to take some pics of the head before they take it apart and send it to the machine shop for checkup.
    Feb 17 2005
    Sarasota, FL
    You obviously know nothing about the B6 A4 and its fuel system. You can not raise the fuel pressure on our cars!
    just for comparison, my gt30r car made 327 @ all 4 wheels @ ~20-21psi. mustang dyno
    contact via email please.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    cyl 1 25%
    cyl 2 20%
    cyl 3 20%
    cyl 4 70%
    Wait. You are confusing me, Winston. This quote is "Percentage held"?? Not "Percentage leak?"
    For my benefit (because this is how I interpret leak-down results), Please keep it as "Percentage Leak".
    -Doug
    Veteran Member Three Rings joe.audi's Avatar
    Nov 28 2006
    b6 a4 ,1985 jetta
    N.H
    ooooooo that sucks
    02 sedan built 1.8 big turbo on meth
    REVO software
    HBC tuning
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    A bent valve will not hold any pressure what so ever, unlike bad rings. A bent valve is like an open hole.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Quote Originally Posted by dirtybrd View Post
    i was thinking the same thing
    you cant have valve damage on a cylinder and only part leak down. if you had damaged valve train pieces that cylinder would have 0 compression
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by k0mpresd View Post
    Exactly, I think he might have burned a piston. I hope not but thats how is sounds. Unless they didn't lap the valves in good enough.
    I'm back bitches!
    or his rings did not seal properly
    Mar 21 2006
    Lakeland, FL.
    Or that.
    I'm back bitches!
    Or that.
    ..check your thread
    Jun 11 2005
    Vancouver, BC
    The rings were sealed fine as everything was cool until the cam chain tensioner failed and something else happened to the exhaust valves at the same point in time.
    My guys are guessing that a valve might be bent or the valves may have been burned. To me it makes no difference as they all have to come out anyway.
    I am hoping that there is no damage to the pistons and rings as that would really piss me off.
    Mar 21 2006
    Lakeland, FL.
    Oh, I misunderstood. I thought the tens. was ok and the noise was from else where.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    What was the cause of all this? Do you know?
    Ive been running up to 7200 recently and dont forsee any problems, you weren't reving above that were you?
    Jan 16 2007
    Wetzlar
    find better shop. what kind of shop does not have borescope?
    Before taking everything apart look inside and make a judgement.
    Nov 27 2006
    High point, NC
    Borescope,lol You must work for an F1 team. Leak is all that needs to be done. Its simple, cylinders dont seal=cylinder head needs to come off. No rocket science there, too funny.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I boroscoped my engine. It was easier than pulling a head.
    -Doug
    Nov 27 2006
    High point, NC
    you can fix valves without taking a head off? You are good man. borescope,hahaha. A good scope costs more then these engines
    http://buy1.snapon.com/products/diag...s/eepv309a.asp
    By the way, only hacks leak down engines. What was that shop thinking
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I never said I fixed anything without taking the cylinder head off. I just said I inspected my valves, post leak-down test, with a boroscope (I borrowed it from work. I use them all the time climbing up the tail end of jet aircraft engines to inspect turbine hardware).
    -Doug
    Nov 27 2006
    High point, NC
    go re-inspect the car. But it seems that the results of the leak pretty much sums it up. Am i correct in saying this?Checking it with a scope is not going to change the leak, or will it? Cant really leak down a jet engine, so a scope would be a good tool to use where as a leak down tester pretty much sums it up for a dinosaur which is the internal combustion engine.
    A 73 Porsche 914/6 runs 2:05's at VIR. 242 whp with a full time Doctor as a driver , if you cant do at least that with 400+ ,then hang it up
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Roy munson View Post
    Your right. Original poster should go tell his shop to go re-inspect the car. But it seems that the results of the leak pretty much sums it up. Am i correct in saying this?Checking it with a scope is not going to change the leak, or will it? Cant really leak down a jet engine, so a scope would be a good tool to use where as a leak down tester pretty much sums it up for a dinosaur which is the internal combustion engine.
    Correct. A leak-down test pretty much tells you if you're piston rings or valves are not sealing properly. If those numbers are excessive then you really should be pulling the head for a visual. If they are within 10-20% leakage then its all up to the owner of the vehicle.
    I don't think Winston (OP) told us his compression test results. Typically that would be done first and then a leak-down (if warranted). With leakage as excessive as his I'm willing to bet his compression test results are bad and out of spec. Which would point you down the road of needing to do a leak-down to better understand why.
    In my case, my compression test results were acceptable and we did a leakage test anyway. I had three independent European Auto Shop's conduct the test. Two of the shops results matched and the third did not. The results pointed to two cylinders having >20% leakage. I did not want to pull my head off for this is my daily driver. I visually inspected with the boroscope and concluded its time to build a new engine.
    So, I'm still driving my car (albeit staying out of boost) and building a new engine on the side.
    Aside.... We use boroscopes on jet engines for visual inspections (erosion, foreign object damage, etc...). Much, much cheaper than pulling the engine out of the airframe (or test stand) and tearing apart.
    -Doug
    Nov 27 2006
    High point, NC
    Its always up to the owner of the vehicle. Personally 20 percent is excessive. The point is that someone had stated before that a borescope would make a difference. Something as straight forward as this has a straight forward answer. Like i said, a borescope is not going to change things, a leak is a leak.Its the most important test of all, above compression. It tells the whole story, not just part. I have worked in motorsport for a couple of days now, i are mechanic, lol. Not trying to start a pissing match with you Dougy, just trying to understand the logic of jumping to the borescope as there is not any ground breaking discoveries being made here.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Hmmm... I must have missed this quote:
    Quote Originally Posted by a2gtinut View Post
    find better shop. what kind of shop does not have borescope? Before taking everything apart look inside and make a judgement.
    And can't find any reference to a borescope prior to that. I was reacting to your comment without seeing the post you commented about. I agree with your point. My apologies.
    Yeah. I'm not happy with 20% which is why I'm building a new engine (AMU block from a TT225). Should I have just pulled my head? Probably, but that wouldn't have told me the condition of my rings (where I'm getting some of that 20% leakage through). I had a second engine sitting in my garage so it was easier to just build that and continue to drive my AVant.
    Of course, now that I've started that whole process I'm picking up a Jeep this week to drive daily. (The Chevelle doesn't get driven and isn't in CT with me.)
    -Doug
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Quote Originally Posted by A4ringedONE8T View Post
    OEM valve train is good for 8k rpms and 500+whp, I know because I was running 100% OEM valve train till my last engine build. I didn't get any valve float till I started going past 8k rpm which caused them to get bent when they hit the tops of the pistons.
    Feb 17 2005
    Sarasota, FL
    So I shouldnt worry going to 7200?
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    I go to 7000 everyday like it's my job, I don't think another measly 200 is gonna make a difference.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
