Results 1 to 11 of 11
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    What do I need to replace here?
    It was quite fortunate actually... As I pulled in my driveway, my driver's side xenon takes a shit on me. earlier tonight, I noticed that it had turned a purple/pink. Then as I pull in for the night, goodbye.
    sooo... what is it exactly i need to replace? ignitors? ballast? the bulb?
    I think from lurking on here long enough it's the bulb, but i know someone has had this happen, and can you point me in hte right direction? (step up from OEM. I was thinking 55W 6000)
    thanks guys,
    Matt
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Senior Member Two Rings WingsnHorns's Avatar
    Feb 09 2008
    '00 S4
    Vancouver
    Re: What do I need to replace here?
    Try switching the bulbs, if the driver's side is still not working properly then it's the ignitor/ballast.
    Senior Member Two Rings lfloodt's Avatar
    Feb 18 2008
    Black '05 A4 Avant 3.0Q 6speed
    philly, pa
    that's what i was gonna say^. you can switch out the bulbs as a test.
    '05 B6 Avant/6 speed/3.0Q / De-cupholdered armrest....
    Oct 25 2007
    Seattle wa
    I'm thinking it's the bulb, I noticed my stock bulbs were going purple/pink on me. I looked at them and saw that a spherical part inside the bulb had "frosted" over, and the one that had turned more was more frosted. If you were to go 55w, you'd need a new ballast, and with that, some custom mounting I've heard. I'd just look for some 5 or 6000k bulbs from a reputable source (I'm sure someone will link you to a trusted site) and call it good.
    2000 Nogaro S4 sedan
    -AWE Downpipes
    -AWE Twin2
    -GIAC-X
    -Stasis Street Sport
    Jul 07 2007
    Tempe, AZ
    ok.. i'll switch em out today. but i was pretty sure it's the headlight. so, im leaning for a 4500k or 6000k made by ziza on ECStuning. hows that sound?
    Established Member Two Rings Rane_kn's Avatar
    Jan 12 2008
    Orlando, FL
    I was actually going to ask if I needed to replace anything on my lights. Far as I know they are stock an older guy had the car before me so there was hardly anything done to it. But I've been noticing a color difference in my lights over the past few months. At first sight they look great but once they are on for a bit they have a greenish yellow tint to them. Are my projectors burnt up I heard that happens sometimes?
    Jul 07 2007
    Tempe, AZ
    i've heard that the lens itself can get quite nasty on the inside due to heat or something from the bulb. and that you can wipe it out with some shit. I'm ordering the 6000k overnighting (no shipping sunday, so i'll be legal to drive nights by tuesday night for sure lol.
    any tips on replacement? i checked Audidiy.com but they didnt have how to simply replace the bulbs. i did headlights a couple times on my old Maxima, and it was fucking simple, so...
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Quote Originally Posted by jungb5s4 View Post
    Our cars are the same way. Simple. Pop the hood, pop off the black cover with the yellow electric triangle on it, and pull out the bulb. Unless you have bigfoot hands, it should take like 3 mins.
    Dec 06 2007
    Calgary, AB, Canada
    As a general rule, if the bulbs are changing color, the bulb is dying.
    If the lights are flickering or getting dimmer, it's the ballast.
    Jun 14 2007
    2000 S4
    Connecticut
    i did this and learned the hard way, BTW i had the ECS ZIZA 6000K bulbs, they are awesome. But pull the plug out of the xenon bulb, THEN undo the clip. THEN when you reinstall put the bulb in its place, then make the clip go, so the bulb should be in there just as it should THEN replug, i tried replugging then getting the clip over that i must of said fcuk over 1million times. =]
    Jul 07 2007
    Tempe, AZ
    lmao thanks 4 the advice guys
