Results 1 to 18 of 18
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    Starting my GT build this week finally
    My build will consist of a custom GT setup made for my car, I will be running GT2560ss on the bone stock motor.. 44mm tial gates all mandrel bent custom aluminum inlet pipes, custom mandrel bent aluminum Bi-pipes 1 piece no welds everything ceramic coated... 3 inch SS V band dps to a 3.5 inch exhaust, custom twin liquid coolers... Pic of my 1 piece Bi-pipe I will be using. I will post progress pics when I actually make some progress
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Re: Starting my GT build this week finally
    lovely build cant wait to put mine on my other car :)
    Sep 19 2006
    Boston
    ahhh so your about to begin yours as i begin mine... intersante!, ITS A RACE! Muahahah, I'm just waiting for the clutch to arrive and small stuff...
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Long Island, NY
    nick im waiting on your clutch then we are all good :) i can pencil you in somewhere for the install
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    After all that work, how come you decided against throwing some rods in there? All else aside it seems like it would at least be cheap security.
    Sep 19 2006
    Boston
    he probably has lowering compression head gaskets
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Mar 14 2007
    michigan
    I'm not touching the heads, they will remain bone stock maybe at the very most 2.8 cams that i have laying around thats it... I'm not a track guy nor am I trying to build a race car, once tired of the car or until i break something then it will get built but for now just wish to play around and have some fun......
    Active Member Four Rings
    Dec 11 2006
    Boston
    Nice, looking forward to seeing this come along, as well as the results. Is Greg0r doing your toon?
    And for your sake, I hope everything was backpurged! = )
    Keep us posted
    Stage 3+ RS6's
    Mar 14 2007
    michigan
    Nothing gets welded here without purging haha.. The bi-pipes have no welds in them just the one for the diverter nipple, the pipes where pressure tested at 200psi...
    Dec 11 2006
    Boston
    oooh those are some pretty upper intercooler pipes. looks like stock throttle body...?
    what are the rest of the details on this setup?
    Stage 3+ RS6's
    Mar 14 2007
    michigan
    I just got back all my piping from the mandrel bender along with my bi-pipes everything is ceramic coated like i mentioned above, this will hopefully keep the heat down a bit... cm4 with the 034 steel single mass flywheel, Greg will supply me with the tune... I will post all the turbo components for my build soon....
    Long Island, NY
    im waiting for my new bi pipes also its amazing how constrictive the stock bi pipes really are. I hope these will open up some flow for me at top end.
    Senior Member Three Rings rcjustin's Avatar
    Aug 29 2007
    00 s4
    Im picking up a set as well. APR bipipe for sale.
    Quote Originally Posted by 2001S4NY View Post
    Silver SSP Stage 3+ S4
    Veteran Member Four Rings GURUMAN's Avatar
    Mar 13 2007
    2.9L PTE 6766 1000 Bhp single Monster !
    Montreal
    Hey bud, i was to send you a pm but maybe more than me wil face this problem. I have same stype piping than yours that connects to a Samco TBB. My problem is by changing to a 75mm throttle boby, I'M fu&ked, the boot wont fit anymore.
    Have any suggestions ?
    Jan 11 2007
    Salt Lake City, Utah
    So did we ever come to a general consensus on if we want the uppipes to conduct and dissipate heat because of their location with airflow going over them, or do we want them to be well insulated because the heat of the air after flowing through the radiator is greater than the air in the pipes after the intercooler? I don't think it was ever clearly resolved one way or another.
    Mar 14 2007
    michigan
    Quote Originally Posted by GURUMAN View Post
    If your running a larger T.B then stocker then the Bi-pipes isn't the problem you will face it's the Boot like you mentioned.. If i had this problem and I don't I would simply merge the bi-pipes into 1 at the T.B and run a single coupler,this very simple for anyone who can weld...
    Mar 14 2007
    michigan
    Guys this isn't a Bi-pipe thread, I was simply showing the progress of my build, please lets keep the thread on topic before it gets locked for not following the rules.. Thanks
    Veteran Member Three Rings cjk's Avatar
    Jul 15 2004
    2001 WB S4 Avant
    Seattle, Wa
    Looks good shawn! I've been meaning to shoot u an email to chat...just haven't been into the car for awhile, and probably won't start until early next year.
    Look forward to seein more data and info!
