Results 1 to 8 of 8
    Veteran Member Three Rings B5Burn's Avatar
    Feb 25 2007
    1998.5 A4 2.0BT
    Winnipeg, Manitoba Canada
    2 wiper blade sizes for better performance?
    I can't wrap my head around whether this would work... For those of you who have the silicone or newer single blade style wiper blades (Reflex, Bosch)... do you get that little inch or two of passenger side windshield that never gets cleaned due to the curve in the window? (outside windshield edge nearest the pass side mirror).
    I have two cars I am going to by blades for this week end... was thinking, what if I bought 1 size smaller for the passenger side? Would the shorter blade do a better job of the lower window edge that the long blade can't wrap around? Obviously it is cleaning less area, but will it clean that outer area a little better?
    B.
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    Re: 2 wiper blade sizes for better performance?
    i have the same problem, but i have noticed that on some cars the pass. side blade is curved a bit, my car had that when i bought it, but in theory it would work. I have a 21 on the driver side and a 20 on the pass side. But if it does work let me know cause it annoys the shit out of me to.
    Feb 25 2007
    1998.5 A4 2.0BT
    You say you've seen a bend in some... do you mean like people are cranking it a little on the end? If it was the brand, I'd buy something else, but I see all of them do it.
    Mar 24 2008
    Illinois
    its like curved, i dont know if thats what they come with or what but check out this vid, and pay attention to the wipers.
    http://youtube.com/watch?v=DFxWVepU9zI&feature=related
    Feb 25 2007
    1998.5 A4 2.0BT
    I think that's just an illusion, mine look like that when they are on.
    Registered Member Three Rings
    Sep 30 2007
    has too much crap to fit a car
    Upstate, NY
    The normal wipers tend to get that spot alot better... the internal spring wipers will usually miss it. The OE aero wipers dont miss a single spot... they have a stronger spring in the arm as well as in the blade... makes for a great combo!
    I understand your theroy... and the only way to know would be to try it out. I use a longer than oe wiper on my driver side (22") and OE on the stock size on the passenger.
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    Quote Originally Posted by arorem View Post
    that car is slow...
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Search for the tire rack bogo thread. I measured out what sizes would fit.
    Jim
    I Do Werk.
