Results 1 to 9 of 9
    Senior Member Two Rings Erock's Avatar
    Widebody S4 Avant
    replaced the mass air flow and still problems
    well on my way to work this morning my car dies for no reason so i get out after numerous tries of restarting and still nothing so i unplug the maf and it fires right up but misfires at 3k. So today i picked up a another maf and put it in and it started right up but as soon as i hit the gas it died. What would cause that to happen? could it be another maf dead?
    98 pearl white BT A4- gone but never forgotten :(
    01 widebody S4 wagon porsche speed yellow Tial 605's and all that goes with it :)
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    Re: replaced the mass air flow and still problems
    how your plugs looking? covered in gas?
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Oct 16 2006
    Portland, OR
    Yeah change your plugs! Its unlikely that the new MAF is dead already.
    Feb 29 2008
    Durham/NC/Southeast
    i have seen this caused by a bad fuel pump. It would only make 1 bar of pressure. With the mafs unplugged in a limp mode it would run but as soon as you plugged it in and tried to take off it fell flat on it's face.
    However it more likely is a giant boost leak. IC hose blown off etc.
    Widebody S4 Avant
    the weird thing is that when i drove it home from work with the maf unplugged it boosted to 12psi and yes my plugs are covered in gas
    Veteran Member Four Rings UN-PIMP-Z-A4's Avatar
    Jan 29 2007
    MR VTEC Lives...
    Yes We Can!!! Obama N Beyond!
    When that happened to me my pcv valve had cracked and i hadnt noticed until i went to change my injectors...
    (which caused a major boost leak)
    Homebrew PES Powered Stage 3 A4 1.8TQM It can be yours for only $5k PM for details
    I have a JUSTINTERCOOLER 27 X 6 X 2.75 WITH 2.5" inlet / outlet (Brand New in Box) FMIC for Sale $90
    QUOTE OF THE YEAR:
    "Another thing, dont go flashing 15 second timeslips!"
    Registered Member One Ring llA4benll's Avatar
    Mar 24 2008
    1997 audi a4 1.8t
    clifton
    i had a problem like that, try checking all of the wires that are plugged in the MAF. Make sure there are no cracks . and pull on the wires a little bit to make sure they dont just seperate easily.
    Euro Performance
    77wabash ave
    clifton n.j 07013
    Active Member Two Rings MacA4's Avatar
    Sep 26 2006
    01 1.8T Q
    PA
    Check for boost leaks mentioned above. I came across a friend and his car would start and Idle... but as soon as he tried to take off it died. Turned out to have a hose come off before the inner cooler.
    Widebody S4 Avant
    fixed the problem with new plugs a new maf
