Results 1 to 9 of 9
    Established Member Two Rings mattdogg02's Avatar
    Nov 12 2007
    Lucas, TX
    Xenon/BiXenon/eCodes Question
    In my quest to learn more about the options for my S4, in my research of the headlight options, had a couple questions:
    Do the S4s come with the Xenons standard, are they single Xenon or BiXenons (is this an available option?), can you go from Xenon to BiXenon with only the housings? Or in other words, if you have Xenon, and someone is selling BiXenon ecodes, is there an issue there?
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    Re: Xenon/BiXenon/eCodes Question
    b6 s4 comes stock with single xenon and you can upgrade to bixenon...i am not sure about the ecode question..
    Feb 04 2008
    04 S4 6MT; 08 328xi 6MT
    Philadelphia, PA
    I thought 04 B6 came w/ single xenons and 05 B6 came w/ the bi-xenons...
    Nov 12 2007
    Lucas, TX
    So... 150+ views and no resolve... bump
    Senior Member Three Rings JoeM's Avatar
    Nov 01 2007
    Vancouver, Wa
    mine is an '05 and I'm pretty sure it has aftermarket Bi-Xenons, since they are black housings.
    -Joe-
    '08 A4 2.0T Q
    '01 Land Rover Disco II
    '99 Porsche Boxster
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    My 05 has bi-xenons so 05 was the change
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Nov 12 2007
    Lucas, TX
    So, can an 04 buy the aftermarket bixenon ecodes and not have an issue? Is it only a housing with a larger lens or something else...?
    Oct 14 2009
    R
    and the answer is?
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    Q7 TDI | B6 S4 Avant MT | 84 Adventurewagen | 53 Ford Jubilee
    MI
    Quote Originally Posted by PhilaS4 View Post
    this
    Quote Originally Posted by mattdogg02 View Post
    from the looks of it, the connector is the same, but I have no idea if you can swap them straight out. The housing is completely different between the two.
    -justin
