Results 1 to 10 of 10
    Veteran Member Three Rings ridelikeme's Avatar
    Jun 15 2005
    B6 A4 , Avalanche LT,
    Calgary
    Help: Car starts and then dies immediatly. (flashing symbol of car with key under)
    just as the description says.
    i removed the battery cables to do some maintenace, and when i tried to start the car back up it was in safe mode. so i used my code and that only reset the stereo. the car starts up fine, but then dies right away. there is a flashing symbol of a car with a key under it. and i have no idea what it is
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: Help: Car starts and then dies immediatly. (flashing symbol of car with key under
    It is you immobilizer kicking in.
    You will have to relink the keys to the car since you disconnected your battery. Right now your remote should not work to lock/unlock your car.
    IIRC to relink the remote you press the top button while turning your key to position one and hold for 5 seconds.
    Jun 15 2005
    Calgary
    that did not work Winston, but thanks for the attempt. do you know if our car has immo 1 of 2, im going to assume immo 2. however i would like to be sure before starting
    Jun 11 2005
    Vancouver, BC
    I believe we have version 2 in our B6's
    Veteran Member Four Rings gdawg'05a4's Avatar
    May 03 2005
    '17 Q7, '95 Audi 90 AAN Swap
    Boston
    First unlock and lock the door with the key manually. Once you get in, put it into the ignition but don't turn it. Press the lock and unlock button on the remote a few times.
    '17 Q7 3.0T | Graphite Gray | Rock Gray || Prestige | Cold Weather | Tow
    '14 A6 3.0T | Daytona Gray | Black || Prestige | Cold Weather | Driver Assist | Rear Sunshades | 19" Sport
    EPL S2 + TCU
    '95 90 Quattro Sport MT5 | Pearl | Black || 20vT AAN swap
    Previous Cars:
    '12 S4 | '13 Q5 2.0T | '11 A4 2.0TQ | '07 A4 2.0TQ | '06 S4 25quattro | '05 A4 1.8TQ MT6
    Jun 15 2005
    Calgary
    not working.. thanks though.. im going to have to recode through Vag-com i think. something is up for sure. is our IMMO located in the cluster or is it in a separate location?
    Junior Member Two Rings
    Jun 30 2007
    Greenville
    one of my keys will unlock/lock the doors but will not crank the engine. The ECU was replaced in the car before I bought it and the spare key was not sent off to the dealership before they swapped it.
    Is there a way I can get the second key to work as well ?
    Active Member Two Rings cmlteg's Avatar
    Oct 29 2006
    Your keys lost synchronizacion with ur immobilizer, if u take it to the dealer bring all your keys they would synchronize them.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    it doesnt start after you try a 2nd or 3rd time? My car does the same thing like every other time I go to drive it. I have an appointment with the dealer in 2 weeks to get it fixed. It is the key reader which is part of the ignition switch where the key goes in. It controls the immobilizer and the keyless entry. Mine will start then die (flashing symol) then I turn key off and on again and it cranks. I asked a year ago and they said it would be like $350 for parts and labor to replace it.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Veteran Member Three Rings Pete4 1.8t's Avatar
    Jan 13 2007
    '12 328i Sport, Others: '12 A8L W12, '12 S5 Cab, '11 P. Cayenne, '13 P. 911 C2S
    Greensboro
    Does it do this with all of the keys?
    2003 Audi A4 1.8t 5-Speed
    Light Silver with Ebony Leather with Premium Package
