Results 1 to 9 of 9
    Senior Member Two Rings Kat_Somm_Faen's Avatar
    Sep 02 2004
    Boulder, Colorado
    Vibration While Braking
    Hey all,
    Any ides what is going on? I got an 04 that gets this slight vibration in the steering when I am on the highway. Kinda annoying... braking seems fine and it performs OK but the steering wheel vibrates.
    Anybody had something similar?
    THX!
    "Goodbye, my friend, goodbye
    My love, you are in my heart.
    It was preordained we should part
    And be reunited by and by.
    Goodbye: no handshake to endure.
    Let's have no sadness -- furrowed brow.
    There's nothing new in dying now
    Though living is no newer."
    "And so I leave this world, where the heart must either break or turn to lead."
    "Those who live outside of society become either Gods or Deamons."
    Mar 11 2008
    B7RS4 & e46Ms
    Re: Vibration While Braking
    Could be a few things if it's consistant, braking or not... bent wheel(s), tire(s) out of alignment, wheel bearing(s) going out.
    if it's only braking, then you'll need to either have your rotors turned, or buy new ones... read here if you wish to learn more about why your brakes pulsate... Knowledge
    Veteran Member Four Rings junkie1.8TQ's Avatar
    Dec 03 2005
    2004 A4 1.8TQ
    Charlotte, NC
    X2 most likely warped rotors.
    2004 Audi A4 1.8T Quattro 6-speed
    • Bilstein PSS9 • APR Stage 1+ w/ TT225 Injectors • Forge 007
    • JHM SS • Oettinger RZ 19x8.5 • Podi • RS4 Rear Sway
    Dec 13 2007
    St Paul, MN
    X3 warped rotors.
    Veteran Member Four Rings michgo's Avatar
    Oct 21 2007
    Wagon/Variant/Avant A4 B6
    x4 warped rotors.
    the stock a4 ones can quickly be warped after a single hour of hard driving.
    I heart wagons.
    'It's actually a pretty big pet peeve of mine when people mess around with my photos', MmmBoost
    shave it mold it sand it paint it
    Veteran Member Four Rings A4Shizl's Avatar
    Jun 11 2004
    2003 Audi 1.8T, 2005 Honda
    Inland Empire
    they beat me to it ..
    x5 on the warped rotors...
    Established Member Four Rings A4TL's Avatar
    Nov 06 2006
    335is
    atlanta
    turn the rotors and use a torque wrench on the lugs always.
    02 1.8tqs - apr 1+ - SS forge - Hartmann B5 RS4 18" ET35 - Delsa (ebay) spoiler lip - debadged, B7 A4 320mmx30 front brakes - 335i Montego Blue/black; Sport;Prem; iDrive; Step and Heated Seats.
    Dec 21 2007
    Romania
    Brake disks
    Mar 27 2005
    The Cold North
    Here's another scenerio. Your rotors may be fine, but you may have un-even pad material transfer. I am dealing with this issue right now as i just bedded a new set of Ferrodo DS2500 pads and those pads were not compatible with the prior pad material (carbotech Bobcats) on the rotors. it feels liked a warped rotor sensation, but it is actually uneven pad transfer.
    Quote from Stoptech:
    "The all-important transfer layer
    As stated above, the objective of the bed-in process is to deposit an even layer of brake pad material, or transfer layer , on the rubbing surface of the rotor disc. Note the emphasis on the word even, as uneven pad deposits on the rotor face are the number one, and almost exclusive cause of brake judder or vibration.
    Let's say that again, just so there is no misunderstanding. Uneven pad deposits on the rotor face are the number one, and almost exclusive cause of brake judder or vibration.
    It only takes a small amount of thickness variation, or TV, in the transfer layer (we're only talking a few ten thousandths of an inch here) to initiate brake vibration. While the impact of an uneven transfer layer is almost imperceptible at first, as the pad starts riding the high and low spots, more and more TV will be naturally generated until the vibration is much more evident. With prolonged exposure, the high spots can become hot spots and can actually change the metallurgy of the rotor in those areas, creating “hard” spots in the rotor face that are virtually impossible to remove. "
    Stoptech White Page Article on Pad Bedding
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
