Results 1 to 22 of 22
    Jan 09 2008
    01'NB'S4 sold 04 LSBlue M3
    VA
    Almost crashed last night. What's wrong with my brakes? Help!?
    So it was pouring last night and I was on I-66 making my way over to Arlington, VA to meet some friends. The mini van in front of me tried merging right at the same time a car was merging into the same lane from the other lane. Both swerved out once they realized it and the mini-van slammed the brakes. I maintained a safe distance so I saw it coming, but as I tried braking slowly, my car didn't slow down... The car just seemed like it was gliding forward without stopping. I pressed even harder, and the car slowed down ever so slightly, but without much of a "braking" feel. I downshifted from 6th to 4th and then to 3rd as I was braking because the car didn't seem to slow down much. I ended up being about a few feet away from the mini van.
    So after that I was a bit shook. Went to meet my friends, hung out, and then made my way home. On the way home, right before the highway ramp, I came to a slow stop from 45 mph at a red light. I gave the brake some slight pressure, and what do you know, the ABS kicked in for a split second. Oh, and it was no longer raining on the way home. Weird. I get on the highway it was pretty empty at 1:30am so I did a 90-50 mph stop. Same thing. Car felt like it was gliding forward without stopping, and only until I gave it some decent pressure did the car "start to stop." [O_O]
    What's wrong with my brakes? If it helps any, I am noticing my brakes squeal like crazy just backing down my driveway in the morning. Also sometimes when my car sits in the garage for a full day and the car is started and rolled out, I hear a clunk in the front but haven't pinpointed it yet.
    Your help would be greatly appreciated thanks.
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Re: Almost crashed last night. What's wrong with my brakes? Help!?
    My brakes squeal like crazy when I'm backing out of the driveway too, but I've never had the gliding sensation you experienced.
    Have you checked your brake fluid recently? Maybe there is a leak in the hose. Maybe its not creating pressure to the calipers? (for lack of a better term)..Was the time with the minivan the first time you experienced this problem?
    This is a quite a serious problem. I'd put it on the top of my priorities, unless you have another daily driver.
    Jan 09 2008
    VA
    Quote Originally Posted by tike0rz View Post
    Yea it's pretty serious. The thing is, brake pedal feel is decent. I did check my brake fluid and it seems like it's good, but I can't tell because I can only see the damn tank from the top. I tried jiggling it around and saw the fluid sloshing in it, and it seemed to be at a good level.
    Dry pavement braking is good, but during hard stops the car just doesn't seem to want to brake.
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    If the ground is wet and you brake hard, you will slide, raining or not. Maybe you experienced hydroplaning?
    Otherwise, you don't have a closed system anymore, and slight pressure leaks fluid and doesn't brake, and big pressure leaks still, but you have enough flow to stop. If this was the case, you would have alot of brake fluid wetness on the back side of your upright and probably all over your wheel well, and your fluid level would drop.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Get off the road my friend. I had the exact same thing happen to me. Turned out to be a busted brake line. It's some scary shit. Stop driving asap because it will only get worst. Mine happened on a sunny day so I could see the brake fluid in my wheel. My cv boot was somehow rubbing against my hard brake line and it eventually wore a hole in it.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 05 2007
    also pressure test and see if the brake booster line (the hard line that snakes into the firewall just to the left of where ECU sits) is cracked or leaking.
    it has a plastic tee (check valve?) with 3 lines (1 to back of manifold, 1 to larger rubber grommet in firewall, 1 into the accordian hose base)
    mine was leaking and i was getting a bit of 'chatter' at high speed braking (80mph+) which is gone now that i've fixed. In searching here and AW i came across some anecdotes that it caused some scary braking issues for others, too.
    Jan 09 2008
    VA
    Thanks I'll try to do that this weekend. Car brakes fine under dry conditions. Brake fluid does seem like it's normal, but can someone chime in and tell me if there is a more accurate way of checking the fluid level? The tank can only be seen from the top as far as I can tell, and I can't seem to see the "max and min" level lines.
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Stick your finger in the fluid resevoir and check the color. If it's dark, it's time to change it. Brake fluid should be change every 2 years under normal usage. I'd also recommend what the others suggested about checking your lines for fluid leaks and testing the brake booster line. I had a scary moment myself when the line disconnected completely doing 60mph down the highway. Roads were dry and I had no brakes.
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Apr 18 2007
    b5 s4 nogaro , 1991 bmw 325is 5spd
    florida,wellington & hollywood
    hahah same hing happened to me check your brake booster valve its prob broken and pops back in sometimes
    Account Terminated Two Rings
    Feb 18 2008
    Venus
    Get B7 RS4 reps, and this will never happen again. You'll look so cool, you would just want to cruise all the time, and brakes will be a thing of the past.
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Quote Originally Posted by hyperlight944 View Post
    If this has happened, don't just pop it back in, replace the line. I put 4 zipties around that bitch to make sure it wasn't going anywhere until I could order the hose (dealer only). Probably around $90-$100, but WAY less than an accident. DON'T RISK IT!!!
    www.NJSRealty.com
    Senior Member Two Rings Fast Euro's Avatar
    Mar 23 2007
    2005 SLK55 AMG
    Buffalo Grove, IL
    I got bizarre wet braking behavior from time to time - had it ever since I got the car a few years back. It almost seems like the brakes get soaked and don't bite as well until I hit them harder once or twice... but it doesn't seem as bad as what you're getting.
    Mar 23 2007
    2005 SLK55 AMG
    Buffalo Grove, IL
    Quote Originally Posted by KompMan420 View Post
    Is this the line tha connects under the accordian hose? Where does it normally pop off from?
    Jun 02 2007
    2004 cbr600 rr 1988 16V scirocco
    vancouver
    the brakes are automatically lightly applied by to keep the rotors dry so that shouldn't be an issue
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    Quote Originally Posted by Fast Euro View Post
    The brake booster line is the curvy 'S' shaped hard line coming out of the firewall and under the Y-Pipe. It then splits into two ends. It's at this split that it popped off for me.
    www.NJSRealty.com
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Quote Originally Posted by JayyyyyC View Post
    As i told to somebody else in this forum, don't remember who, it's a wheel sensor. My friend s4 did same thing. There was like no brakes until almost stoped then you could hear the abs and after full brakes.
    Veteran Member Four Rings nizmosx's Avatar
    Feb 13 2004
    2007 b7 a4 6MT Ti avant / 1990 300zx TT / 2014 Honda Grom / 2012 Tiguan SE
    Lakewood, CA
    i have a complete set of a4 brake lines if they are the same as s4 i will sell em for cheap.
    Apr 18 2007
    hah relax an i took it out an epoxied it with industrial grade epoxy ...that hoe is gon nowhere for now ....i needa get a new one but have been way to busy
    Dec 06 2007
    Calgary, AB, Canada
    MY '01 and up had the split. On the '00 it just went directly from the intake mani to the firewall. It's simpler for us '00 boys
    Awaiting Confirmation Two Rings
    Sep 14 2007
    02 Laser Red S4
    Charlotte, NC
    Is the hose y'all are talking about the spider hose?
    Veteran Member Three Rings beerock's Avatar
    Mar 26 2005
    widebody babay
    this is the piece you need to look at, it might be sitting like this,
    and when you get on the gas the vaccum decreases and it pops off
    I epoxied mine Supposedly even with a new one it can happen again.
    2001.5 Audi Laser avant 6 speed Asp stg3
    Apr 05 2007
    it was ~$78 delivered from Craig at www.genuineaudiparts.com ..
