Results 1 to 10 of 10
    Senior Member Three Rings AudiSeefu's Avatar
    Sep 14 2006
    Fort Myers, FL
    Terrible start to my day......
    I bought some Hitachi E coils and ngk plats and was gonna put them in just now. I start off by breaking the brittle ass clips off 2 of 4 coilpack connectors. Oh, it then gets even better........all of my coilpacks are swimming in oil. I assume it is my vcg so I just ordered the kit from blauparts. I was so pissed I just plugged the coilpacks back in. Started it up and ran perfect. My question is will it be ok to drive the car until I change the valve cover gasket?
    http://members.cox.net/audiche/maxfrontsigtemp.jpg
    -Che
    1998 Audi A4 2.8
    2002 Audi A4 1.8t
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Terrible start to my day......
    lol....2 of my 4 connector clips are broken too...just make sure you seat them really well.
    As for the VCG...its fine for now
    -Sami-
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    the fen post owner broke one of the clips so bad i have to get a pick to open it up. And of course when i had a coilpack blow it was that coil.
    Sep 14 2006
    Fort Myers, FL
    yeah, those clips are so brittle. I have never had a coilpack go bad *knock on wood....so therefore never changed a coilpack. Just changing them for preventative maintenance. All I suceeded in doing so far is finding more shit that needs to be fixed.
    -Che
    1998 Audi A4 2.8
    2002 Audi A4 1.8t
    Dec 09 2007
    01 gti
    boostedville NJ
    damn coil pack issues.... its like the plague
    VW/Audi
    Sep 14 2006
    Fort Myers, FL
    well.....technically my original coil packs are still running like champs. it's the damn valve cover gasket.
    -Che
    1998 Audi A4 2.8
    2002 Audi A4 1.8t
    Established Member Two Rings sloweryucf's Avatar
    Feb 21 2008
    2003 A4 1.8T (sport package)
    Orlando, FL
    Quote Originally Posted by AudiSeefu View Post
    Question for ya brother, I have some oil around my coil pack, but I'm not sure if it's from me spilling oil from an oil change or not. It isn't in the spark plug well it's in the little crevice about the coil pack. Is that a valve leaking?
    GO KNIGHTS!
    Feb 17 2005
    Sarasota, FL
    If there is oil around your plugs, I would not drive (or start) the car until the valve cover gasket is replaced and the oil is cleaned out. You can pull the plugs and let the oil drain down on the pistons, it will immediately burn off on start up. Oil around the plug can (and will) short the coil packs out very quickly
    Feb 17 2005
    Sarasota, FL
    Quote Originally Posted by sloweryucf View Post
    If your valve cover gasket is leaking you will have oil on the actual plugs, or of course leaking down the side of the head/block if its the external part of the gasket. Outer leakage typically occurs in the back left hand corner and around the cam adjuster
    Feb 21 2008
    Orlando, FL
    Roger that, thanks.
    GO KNIGHTS!
