Results 1 to 28 of 28
    how do you launch ?
    slipping the clutch or a dump from 6k?
    and what turbo set up do you have?
    contact via email please.
    Jan 25 2006
    A4 2.0T
    MD
    Re: how do you launch ?
    My best launch @ the track came from a 6k - 6.2K DUMP!!!
    Let the cluch do the work.
    Veteran Member Three Rings jm121189's Avatar
    Jun 05 2007
    Portland, ME
    I usually take it to about 4k and then slip it a little and the car takes off like it's ass is on fire. It's fun to see your floor mats lift up and bend back. I don't think dumping it at 6k is a good idea unless you have a serious clutch & don't mind breaking some stuff after a few launches.
    I'm on a stock ko3
    2000 1.8t A4 qtm gone but not forgotten
    2008 R32
    2015 S4
    Quote Originally Posted by Don Supreme View Post
    i think i need a new clutch then
    Oct 29 2005
    10speed
    San Francisco, CA
    I rev up to 5-5200 and just drop it with my k03... I do the blipping the throttle technique also but just a straight up rev and drop works fine also
    - Clint
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    If you set the clutch at the friction point there is less stress on the clutch when you release it all at one time. You dont want to dump or side step the clutch with the pedal at the floor since all this does is cause the pressure plate to bounce off the disk.
    Every run I make is by going WOT and releasing the clutch all in one motion with my knee.
    Veteran Member Four Rings 94jedi's Avatar
    Dec 07 2004
    Oly Platform, Pendlay bar, bumpers, squat rack, rings, Prowler
    Ocean Shitty Maryland
    I used to drop it at 6k but I would always forget to keep my foot in the gas and thus the turbo would come out of boost and I'd bog lol. I got some nice 2.6 60ft's that way lol...That's when I ran the 14.2 @ ~98-99.
    at first I thought that was just a characteristic of a journal bearing t3/t4 50trim (that it would fall out of boost after the launch) but I finally realized that I just wasn't keeping my foot in the gas.
    The harder I practice, the luckier I get.
    - Gary Player
    Dec 07 2004
    So, after you stage, you "set-it" at the point where it's about to grab? is that what you mean by friction point? While you're waiting on the lights, what RPM are you at? that sounds like a pretty hairy procedure to pull off at the track. it's probably something I'd have to practice to get it right.
    - Gary Player
    Quote Originally Posted by 94jedi View Post
    yes..i was a bit confused by "friction point" as well
    Dec 09 2007
    01 gti
    boostedville NJ
    FWD and 2 step set to5500 sidestep clutch dump
    VW/Audi
    Quote Originally Posted by junk t.i. View Post
    except im quattro and running me7...no sem here
    Dec 07 2004
    Quote Originally Posted by k0mpresd View Post
    yea, I thought it might be a silly question but I wanted to be clear on what exactly he's doing.
    - Gary Player
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    by friction point Mike means releasing the clutch pedal to the point where the car wants to start moving forward. I leave my foot on the clutch and the car is almost about to roll forward, i then bring the rpms to about 6k and tap the gas pedal to get the turbo spooling as much as possible, also so that when I release my foot on the clutch, my rpms are already on their way up. I then dump the clutch from that point, keep my foot on the floor until my mph has just about stopped going up so I know I'm not spinning anymore and then shift to second.
    30r .63
    Jul 07 2004
    socal
    Correct. I set the clutch at the point just under of where the car wants to move forward. This means the clutch needs less movement when releasing the clutch pedal. If you use the clutch to pull the car into the "stage" light after pre staging you will already know exactly where that spot is at with the pedal, nice part is this also allows you to shallow stage the car by just getting the stage light to blink before it comes on solid.
    Once I get the clutch set at that point I start bouncing the rpms to where I want to launch, this helps spool the turbo up. When I am ready to launch I just go WOT on the last down sweep of the tach and release the clutch at the set rpm that I want to launch at. This means by the time I reach that rpm the turbo is going to be producing a good amount of boost.
    I have been doing this in my A4 for about 7 years so basically I do it without even thinking about it.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    I'm pretty sure what he means by the friction point is where the clutch starts to grab. You can feel it if you press the clutch to the floor and then slowly lift off until you feel the car start to move. That spot between the movement and the floor is the friction point.
    the homebrew'd s4
    word. thanks
    Veteran Member Three Rings bloodstar57's Avatar
    May 15 2007
    2019 RS5, 2014 SQ5,
    LI, NY
    Quote Originally Posted by bernB5 View Post
    30r .63
    This is how i do it too. I think most AWD need to launch this way to keep from bogging.
    Senior Member Three Rings Solaris's Avatar
    Feb 01 2006
    NC
    I pretty much do what Mike said (actually, he advised me on how to launch properly last year and I immediately got much better 60ft. times). My best times were when I dumped the clutch at around 5k RPM (1.895 is my best). My last time out, I was dumping around 4k and couldn't get under 1.90. This is with K04 PC16 on a 034 stage 2 (400+ HP rated) clutch and 18lbs steel flywheel. I typically hold about 3k RPM with the clutch held right before it grabs, then as the 2nd light comes on, I floor the gas and let the clutch out. At a 4k RPM dump, I saw about a 200RPM drop, so I know I need to use a little higher RPM. At the Show 'n' Go...
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    The only reason i don't like going the all the way to the friction point is because you run the risk drifting forward and redlighting. Using the hand brake makes this a non issue, but for some its alot to do. With my stage 3, i would just dump it at around 4k. Launching at 6k+ is a little much.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Jul 07 2004
    socal
    Quote Originally Posted by AB18 View Post
    Well you dont have to load the car with the clutch, just set the clutch so it is just right below the point of wanting to grab.
    The rpm you launch at depends on where the peak tq and peak hp are made. So usually this means a larger turbo needs to be launched at a much higher rpm.
    If you were to launch a GT S4 you would need to launch much higher then a stage 3 S4 since the peak tq/hp are much higher in the rpms.
    Jan 25 2006
    A4 2.0T
    MD
    If I launched @ 4K I would probably stall *LoL* j/k.
    Veteran Member Three Rings dingguhlbary's Avatar
    Jul 17 2007
    New Jerzzzzzzzzzzzzzzzzzzzzzzz
    man i was jut gonna post asking about this. good stuff.
    Jul 07 2004
    socal
    Done it in my car to get a 2.6 60ft.
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    I do what mike does.. only I'm K03 haha
    ÖMGHI2Ü
    Photography
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    i dump from 5k with the clutch just below where it grabs
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Four Rings D's Avant's Avatar
    Oct 03 2007
    02 BMW 330i
    Illinois
    For a quick street launch, say a Mustang 5.0 next to me at a light in the wet. I bring the revs up to 3000 rpm and just as the clutch is starting to grab I release the pedal/dump it as I feed in full throttle. When I get it just right and the car just does a clean quick acceleration with less strain on the drive train IMO. So I guess I just slip the clutch a little.
    Current '08 A6 Avant S-Line
    Former '99 A4 Avant 1.8t
    Nov 09 2007
    Si,NY
    I've never launched my Audi and have nothing useful to add to this thread,but felt the need to inform u all of this fact.lol I baby my lil yellow submarine. Stock clutch with 122k miles.
    Established Member Two Rings bxultra's Avatar
    Feb 24 2014
    Delaware
    i know this is old and has a lot of helpful info, but is launching possible in a stock setup? Im pretty sure my car is completely stock under the hood. My buddy in his e36 tells me i can but id rather not risk blowing my transmission, or burning my clutch, or anything else that might go wrong if launching on a stock setup is detrimental. I would only do it on wet surfaces though when first starting to try.
