Results 1 to 23 of 23
    Account Terminated Four Rings
    Sep 27 2007
    hate on me <3
    under the knife in, CT
    A/c removal...talk some shit
    i removed a/c from my car today while its tied up on the lift waiting for my poor ass to get money to get some rs6's. so i decided to daily take off some weight by doing something. today it was a/c.
    i went with a belt 680 in length, at this length its pretty damn tight, and close to the crankshaft pulley (the auto-tensioner), but it will not hit. a 685 also works good. the stock size is 730 for reference. 6 ribs in case anyone was wondering.
    removed with the belt part number (dayco)
    parts removed (AND FOR SALE, WORKS GREAT!!!. everything capped once removed so no worries). weight is around 20lbs, plus the rotation weight of the pulley.
    where the a/c lines and evaporator use to be.
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Re: A/c removal...talk some shit
    nice but why do you still have that clutch fan there??
    Sep 27 2007
    hate on me <3
    Quote Originally Posted by 2001S4NY View Post
    i was thinking about removing it but i heard from some people that removing the fan clutch without any sort of electric fan causes s4's to overheat in the summer. have you had any issues with that?
    Long Island, NY
    i never had any issue with that till i installed my FMIC, but anyway its worth removing it and installing a EFK
    Mar 28 2005
    Waltham, MA
    I hope you are planning on short rides. As my car was turning from a DD to club car I was dropping weight. Of course A/C was one of the first intermitted steps I took. Since I was not driving the car on daily basis I did not care, but then I drove to track at Mt. Tremblant, which is about 7-8 hours from my home; I quickly regretted my decision. It was the most exhausting trip I can think of and I’ve driven across half of the world. I was tired and miserable all weekend. In paddock, between sessions, I poured water on my head, but it did not help much. The sad part, it was not even that hot (~90 degrees). As soon as I came back home I begun looking for a trailer and a tow vehicle. If its your DD the weight you save does not worth the sacrifice.
    Oct 05 2005
    richmond va
    get rid of that heavy battery tie down. dealer sells small ones for 4-5 dollars..
    01.5 s4 built bottom with pauter rods , BW rs6 turbos , MTM manifolds , ER intercoolers , 044 fuel pump, EV14 injectors , 90mm maf , vast tune for now ,
    X1 intake , ported intake manifold , ASP 3inch down pipes and true duel cat back .
    Sep 27 2007
    hate on me <3
    Quote Originally Posted by richmonds4 View Post
    funny you saw that...that was a temporary solution. im fixing that tomorrow.
    Sep 19 2006
    Boston
    have you noticed a difference in driving yet? :D lololol im pretty sure the car isnt even back together or moving
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    bro I honestly have thought of the same thing, because I cannot fix all the oil leaks, and it jsut smells like burnt oil when the ac is on
    I have done valve gaskets, cam gaskets, cam tensioner gakets
    and the smell persists
    Apr 05 2007
    they're forecasting this summer in Connecticut will be one of the hottest on record.
    Apr 05 2007
    Quote Originally Posted by Boris View Post
    Boris have you tried pressure washing the engine? If you haven't removed the sludge/gunk from previous leaks it will just keep smelling...
    Registered Member Three Rings ChriS4's Avatar
    Nov 09 2007
    A red one. I hate red.
    Track Whore, CA
    I dont have AC in my car right now (still have the system, just not charged) and it's fine. If it's too hot, I just use common sense and roll my windows down.
    '00 B5S4 - Sold
    '95 Civic EJ1 - Stolen
    Good USA
    Sep 27 2007
    hate on me <3
    Quote Originally Posted by exorcet View Post
    im forecasting to not daily drive my car once its back together, so it doesnt bother me.
    Mar 28 2005
    Waltham, MA
    Obviously I kept windows down most of the time. And at the track front windows must be down anyways.
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    XJ - The next Marc!
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    Dec 06 2007
    Calgary, AB, Canada
    Looking good, I've thought of doing that before. I've also thought about swapping out the power steering system for a non-hydraulic system.
    I have had zero problems with overheating and I have no clutch fan, but I also run SMIC's, not a FMIC FWIW
    Sep 27 2007
    hate on me <3
    Quote Originally Posted by The_Jerbel View Post
    i thought about the p/s also, but if you remove the pulley you will hit the tensioner when you route the belts..nless you make a ilder pulley that is small and weighs nothing in place of the p/s pump. unless you had something else planned also.
    Sep 27 2007
    hate on me <3
    Quote Originally Posted by ///M3 TO S4 View Post
    XJ - The next Marc!
    oh no no its not like that. im just removing things here and there that i dont use....like the trunk carpet, a/c..not sure what ill remove next, but im keeping the cabin area stock.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    So is this car going to be a weekend toy now?
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Feb 09 2007
    Charlotte, NC
    Quote Originally Posted by XJinCT View Post
    thats how it starts.......
    Dec 06 2007
    Calgary, AB, Canada
    I was thinking of running an idler pulley also. Some sort of lightweight unit, so that it would actually be beneficial to replace the PS pulley with something smaller and lighter in rotational mass.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    lol your poor ass is sellin shit off his car to get the turbos...dumbass lol what up
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Aug 06 2007
    audi, subaru, dodge, ford
    Truckee, CA
    Real S4s dont have A/C...
    i ran like that for years, even in CA summertime heat, no biggie.
