Results 1 to 15 of 15
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    Noises and spark plug questions.
    Hey guys, I have some questions that I hope you can help me out with...
    1. I was under the impression that my car is chipped because of the 710n's and samco TBB, so when I changed the plugs last week I went with the one heat range colder NGK bkr7e plugs and gapped them to .028. This afternoon I threw a code for cylinder 6 missfire. Is it possible that the car has a stock ECU and the colder plugs caused the missfire?
    2. There is a creaking noise comming from the front pass. side area, I took the wheel off and everything looks fine yet I really don't know S4's very well. and I don't think its the sway bar bushing but its possible I guess.
    3. My third question is reguarding the horrible noise the car started making tonight on my way home. I was driving along when I started to hear this high pitched on and off sound(kinda like nails on a chalkboard) I was almost home and it started getting more constant, at one point it sounded like a cat and I thought oh god I've run over a cat and its stuck under the car [O_O].
    As I started to pullover it became a solid scraping sound, it sounded like I was dragging a sheet of tin under the car. I was basically infront of my house at this point but stopped in the middle of the road anyway to get out and look, but there was nothing under the car. I got back in the car and just coasted in netural down the hill to my driveway as it made the noise all the way.
    I'm scared to death it could be a turbo, but its dark and raining now so I can't go look at it tonight. any thoughts on this would be great, thanks guys!
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    Re: Noises and spark plug questions.
    make sure axles are tight. Look at break pads check if they all have meet on them. check if wheels are tight. then do a leak down test maby its a pinhole in a rubber tube and is making a high pitched sound. if that doesnt solve anything ide say wheel berring
    Last edited by kingofqueenz788; 04-03-2008 at 07:06 PM. Reason: if that doesnt solve anything ide say wheel berring
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    I think wheel bearing could be an explanation for one of those.
    So you don't know if your car is chipped? go take a gander at the ECU, and if you see a APR/GIAC/revo sticker on it, you'll know. 710n's and a samco don't necessarily mean it's chippd. they're just replacement parts of other parts that tend to die rather easily. I ran a stock TBB and 710A's when I got chpped for about 1 month. a boost gauge would be a surefire indicator as to whether or not it is.
    Our stock sparkplugs are in a fine heatrange as is for having a chipped car. yours would probably be good for a stage III car running higher boost
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Dec 06 2007
    Calgary, AB, Canada
    1) Yes. You need stock plugs for anything up to stage 3.
    2) Get under the car and tug on various things, including the sway bar. If there is play in the bushings, then they should be replaced. That should be done with the suspension loaded up (the wheels on the ground or on ramps)
    3) Could be a pebble in your brakes. Get under there and check for things that look like they're rubbing. If you see nothing, take both front wheels off for a better view.
    Arlington, VA
    thanks for the replys, I don't really think it could be a hose just because it really sounds like metal on metal contact, and I guess it could be a wheel bearing but wouldn't that be more of a long term growing problem? this was instant and all happened within 1 mile.
    as far as the ECU, I did look at it and saw no stickers, took it apart and looked all stock but that doesn't mean it wasn't flashed. The car is just so fast and I can't see how it's not chipped, it could easilly walk all over my significantly modded TT. It could be stock but its awfully fast for a 250hp 3700 or so lb. car.
    Now: 2011 Audi S4
    Dec 06 2007
    Calgary, AB, Canada
    BTW, kingofqueen, it's called a boost leak test. A leak down test is something totally different used to test the condition of the engine.
    eliTTe,
    I doubt it's a WB. Get a boost gauge or VAG the car and log block 115 and you'll know if it's chipped or not.
    Arlington, VA
    cool, I'll VAG it tomorrow... a rock in the brakes sounds very possible, I didn't even think about that. thanks!
    Now: 2011 Audi S4
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    1. Stock plugs are fine. You need to get a boost gauge so you know if you are chipped and more importantly to track down future vacuum leaks.
    2. Don't forget to check you tie rods. They are a common thing to go out.
    3. Sounds like it could be the turbo lady. Hopefully only a pebble in the brake though.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Three Rings Jsmooth65's Avatar
    Aug 10 2007
    '15 BMW M235i, '04 A4 1.8t
    Castle Rock, CO
    Burned out prop shaft CV's sound similar to your third problem. If you want to make sure, raise the car and lay underneath it while someone spins one of the back wheels and listen.
    2004 Audi A4 Sedan, Auto, Black, 1.8T Beater
    SOLD - 2007 Audi S4 Sedan, 6spd, Sprint Blue, JHM tune, JHM trio, JHM LWFW and stg3 clutch, Magnaflow RS4 exhaust, LED tails, TTRS SW
    DEAD - 2000 Audi S4 Sedan, 6spd, Laser Red, FRANKENTURBO Stage 3 VAST Fueling (25psi), ER Intercoolers w/shrouds, SSAC DP and Twin 2, JHM trio, APR Bipipe, VAST Stage 3 clutch and LWFW, Sterns mounts, 034 ICM delete/coil conversion, Vogtland coilovers
    Arlington, VA
    Quote Originally Posted by Jsmooth65 View Post
    never heard of this, hmm. does all 4 wheels need to be off the ground to try this? I checked out the under side this morning and don't see a thing, everything is tight as can be and the brakes showed no scratches that would indicate a rock had been stuck in the pad. I drove it to get some lunch and couldn't get it to make the noise until I was at the drive-thru, this time it almost made a pop sound then the horrible screech.
    I use to work beside a steel yard and this noise sounds just like the trains did when they would pull in and hit the brakes.
    Now: 2011 Audi S4
    Aug 10 2007
    Castle Rock, CO
    I'm pretty sure all four wheels, but I may be wrong. Try jacking up the rear (no ramps, cuz the wheels have to spin), and see if they spin. Otherwise, its all 4.
    Mine made some freaky noises when it went out. Sounded crunchy, rattley, clankey, all of the above. Totally repeatable when I put the car on jacks and spun the wheels fast. If it sounds ok down there, cross one thing off the list I guess.
    Noises from these cars typically come from 1 (or more) of the 10 CV joints, 1 (or more) of the 4 wheel bearings, and support bushings (driveshaft support bearing, rear diff support, etc). If your car has >100k miles, prepare for all of these things to start making funny sounds.
    Arlington, VA
    Thanks a lot for the help, I'll go from here...
    Now: 2011 Audi S4
    Jul 07 2007
    Tempe, AZ
    if your rear is in the air, put hte car in gear and let go of the parking brake. if your front is in the air, engage the parking brake and take it out of gear. if you're on jackstands, disengage both
    Dec 06 2007
    Calgary, AB, Canada
    Just put wedges in front of the front wheels, jack up the back, take it out of gear and release the e-brake. Rear wheels should spin.
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by RolledMySTi View Post
    Sorry man, but I have to say that I cringed when I read this post.
    1. A boost gauge DOESN'T reveal boost leaks with any sort of reliability. That's a fallacy that far too many people believe.
    3. It's not the turbo lady if the car is squealing while idling.
