Almost made my decision to have my new baby: here is the test result in papaer?
I want to hear any advance for me to help me decide whether or not to drive it home (based on the result from Vag-com) Please any invoice will be really appreciated!!!!!
Wednesday,02,April,2008,12:37:20:37192
VAG-COM Version: Release 704.1
Data version: 20071016
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 94290km/58589miles
Address 01: Engine Labels: 078-907-551-AZA.LBL
Part No: 8D0 907 551 H
Component: 2.7l V6/5VT G 0003
Coding: 06711
Shop #: WSC 06435
5 Faults Found:
17521 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
P1113 - 35-10 - - - Intermittent
16826 - EVAP Emission Control Sys: Small Leak
P0442 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16688 - Cylinder 4: Misfire Detected
P0304 - 35-00 - -
Readiness: 0000 0001
Address 03: ABS Brakes Labels: 8D0-907-389.LBL
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D46
Coding: 04395
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00060
Shop #: WSC 06435
1 Fault Found:
00787 - Temperature Sensor in Fresh Air intake duct (G89)
30-10 - Open or Short to Plus - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.LBL
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06435
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.LBL
Part No: 8D0 920 932 L
Component: B5-KOMBIINSTR. VDO D12
Coding: 02364
Shop #: WSC 01417
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 06435
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
Address 56: Radio Labels: 8D0-035-1xx-56.LBL
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00112
Shop #: WSC 06435
1 Fault Found:
00668 - Supply Voltage Terminal 30
End --------------------------------------------------------------------------------------------------
