Results 1 to 31 of 31
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    Suggestion for StageI?
    hi all,
    My 2001 s4 is bone stock, i'm starting to do some modification.
    it's got almost 120,000miles on it, I was thinking about doing intake, do ECU tunning.
    What would you suggest doing before going for more Power?
    how about intercooler, all the hoses, BPV, brakes, and suspension?
    I want to do it right, so I'm asking you guys for right way of doing it.
    And has anyone tried AWE drive train stabilizer?
    My trani kinda bumps when I let go on clutch unless I do real smooth.
    That might be helpful to hold the trani tight with the engine?
    and my speakers are getting bad...I couldn't find any on eBay, anyone know where I can get the speakers with good price?
    What do you think???
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    Re: Suggestion for StageI?
    12000 miles? and search is your best friend
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    http://www.audizine.com/forum/showthread.php?t=128295
    start here before the flaming begins.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Senior Member Three Rings YBLEGL's Avatar
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Ill tell you one thing do not waste any money on a intake the factory intake is the best way to go. Ecu is worth the money, if going with a ECU im of course partial to VAST they make great tunes and lots of people on here love them too.
    MAINTENCE AND STAGE 3 INSTALLS DONE, PM ME, MASS/ RI LINE AREA
    2001.5 S4 SILVER 6 SPEED BUILT BLOCK AND SINGLE TURBO KIT WITH PTE 6262.
    Sep 19 2006
    Boston
    Hi Marc
    B5 Imola S4
    B9 Black SQ5
    B7 Silvaro S4
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    i would invest my money in repairs first then upgrades bec if you make the car faster its only gonna wind up breaking more things.
    Apr 01 2008
    Massachusetts
    i will definitely look into FAQ's...thank you for the warning, RolledMySTi!
    And before I moved to S4, i had japanese cars, and CAI was must. I used to have Magnaflow catback, I wasn't really happy with it, it just made annoying sound while cruising and stuff...
    Doesn't intake make the engine sound some what sexier?
    Anyway, I was just surfing around, and read a lot about GIAC or APR, but not much of VAST.
    So VAST is many of you guy's favorite???
    And I will try to repair what need to be fixed...
    so have you guys tried the drive train stabilizer?
    Veteran Member Three Rings Nogaro_PhiDelt's Avatar
    Sep 15 2007
    2000 Nogaro S4 (Stg 2)
    San Luis Obispo/Burlingame
    Just search chip or ecu in this forum, you'll find a lot of arguments against the pros/cons of APR, GIAC, VAST, etc.
    Also, if you are thinking about going stage 3 eventually, buy the chip to the relative company. APR = APR, etc. (kind of my dilemma, I have APR, but their STG3 is one of the most expensive)
    I've never been in anything other than an APR, but I have it on my S4 and my dad's allroad. They both drive really great, but it all goes down to the buyer..
    2000 S4 (Stage 2)
    ->APR
    ->2B H&R Coil-over Program
    ->17" Flik Lex wheels
    ->ASP Tru-Dual 89mm Exhaust
    ->RS4 Clutch
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    As far as where to start, it depends on what you're looking for. If you want more power, then go chip right first. If you're happy with the power for now and want to improve looks and handling, go suspension.
    If you go chip you should probably do your diverter valves (B5 S4 uses DVs instead of BPVs, but same general concept). The stock DVs tend to spring leaks.
    I love my GIAC... It'll throw you back in your seat. It tends to be the torque master of Stage 1. APR should be a little smoother, but a little less torque. Still really nice from what I've heard.
    2010 Ibis White S4 6M Prestige. Stage 1 (034 Motorsport). ADS, Sports Diff, B&O, Nappa, Tech package, 19" Trispoke.
    SOLD - 2002 Brilliant Black S4 6M ** Stage 1 ** (GIAC-X * JHM "Solid" Short Shifter * 034 DVs/TBB * Avic D3 * Clear Corners)
    http://www.audizine.com/classifieds/...inside-&cat=67
    Veteran Member Four Rings skunkoncrunk's Avatar
    Apr 18 2007
    2006 Subaru WRX
    Cali/Colorado
    Only 12,000 miles on your ride? Is that a typo. If not I hate you.
    -Hooked on Meth-
    BOOSTADCT
    -Mike-
    Instagram: @mdundurs
    S4's Video (Watch in 1080p)
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    oh man....
    SBSC
    I also like to live dangerously.
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Hey Mikes Machine you have a PM
    Jun 14 2007
    2000 S4
    Connecticut
    i think the best intake for your situation would be an AEM, make sure to get the extra tubing so you can mount it lower into your bumper for coldest air possible. Just cut off the exhaust run no exhaust, cheapest most effective way to get power. Deff. get the shark injector chip you actually just plug it into the OBD port and you should be good to go
    Veteran Member Four Rings tike0rz's Avatar
    Apr 17 2007
    B8 A5
    Wow you really know what it takes to go fast!
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Quote Originally Posted by tike0rz View Post
    I was thinking the same thing !!
    Established Member Two Rings crosenhahn's Avatar
    Mar 13 2008
    2001 Audi S4
    Colorado Springs
    I run a custom intake on mine (i.e. DIY) just make sure you heat shield around it... It definitely makes the car sound better, really the only way outside of a STG3 to hear the DV's - I used to be a JDM guy and I love the blowoff (I know everyone here hates the whoosh) but having an open air intake lets you hear them and others around... I have the apr chip pretty happy with it!!! But do things like control arms and regular maintence cuz when things break it is not cheap!!! nor are the upgrades... Happy tuning!!!
    Sep 21 2006
    Norjerz
    youre all idiots...
    SBSC
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Quote Originally Posted by FrimmelNoJerz View Post
    youre all idiots...
    Thank you so much my mom says the same thing everytime she see's me
    Jun 14 2007
    2000 S4
    Connecticut
    lol, i think i know who started this thread so i had to play along, its fun HA
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    lol
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Dec 06 2007
    Calgary, AB, Canada
    Quote Originally Posted by thebigchu View Post
    tee hee....
    they're...the....same thing....
    I think you mean BOV's???
    Just FYI, BPV stands for by-pass valve, DV is diverter valve, and BOV is blow off valve.
    Apr 01 2008
    Massachusetts
    Does anyone know more about the shark injector chip?
    Can't find anything about that and Audi, but Bimmer...
    I think I'm going to get the car checked first, then go with GIAC ecu, do intake, and replace the DV's...
    I really want to upgrade sway bar, who makes the best value?
    Has anyone tried the RS version ones?
    Account Terminated Four Rings BananaBoy_S4's Avatar
    Feb 18 2004
    01.5 Santorin S4
    Fairfield, CT / Manayunk, PA
    Quote Originally Posted by mike's machine View Post
    do ECU TUNNING
    Established Member Two Rings bjs's Avatar
    Mar 22 2008
    Doylestown, PA
    I went with GIAC for my chip in Janurary and I love how it will throw you back in your seat. I also did the RS4 clutch and AWE lightweight flywheel at the same time and I can keep up with a e60 m5 no problem. It really is driver preference though for how you want ride comfort and what not.
    Veteran Member Three Rings NOVAS4's Avatar
    Sep 02 2007
    2003 Audi RS6
    Woodbridge, Virginia
    never read a thread like this before...
    Current: 2003 Audi RS6
    Current: 2008 Acura RDX Tech (daily driver)
    Previous: 2013 Hyundai Genesis Coupe 3.8, 2006 Acura TSX, 2008.5 Mazdaspeed3, 2000 S4 Sedan 6sp stage3-, 2004 Subraru WRX
    Apr 05 2007
    Quote Originally Posted by NOVAS4 View Post
    sung to the tune of 'never met a girl like you before'? at least that's how I read it to MYSELF in My MIND!!!!!!!!!!!!! YaaaarggHHHH!
    Get APR, Samco TBB, two 710N's and start saving money for when the turbos blow.
    /end
    Veteran Member Four Rings S4-ORCE's Avatar
    Apr 16 2007
    01.5' S4 ASP Tuned
    Long Island
    Auto Speed Chip, Samco Throttle Body Boot, 710N Diverter Valves, Piggie Downpipes, Catback Exhaust, Cut a hole in your airbox for a nice intake
    And you're good to go
    Sep 21 2006
    Norjerz
    Quote Originally Posted by BananaBoy_S4 View Post
    do ECU TUNNING
    hahahahaha. whatz teh best tunning???!?!?!?
    SBSC
    Sep 22 2006
    2001.5 AUDI S4
    BOSTON
    Hey Mike Read your PM's
    Feb 18 2004
    01.5 Santorin S4
    supersprint
    Veteran Member Three Rings ms4cd's Avatar
    Mar 23 2005
    Slow buckets
    Just tweak your stock ECU, at the end it's the same thing. Make sure you add all the timing you can!!!
