Results 1 to 4 of 4
    Established Member Two Rings mark_2328's Avatar
    Apr 04 2007
    Fargo, ND / Brainerd, MN
    Rear Brake Stuck! HELP!
    So I wash my car after a week of being out of town, and afterwards I notice a distinct burning smell. I look around to find out it is my rear driver's side brake. I drive back home (because I had to!) and it's been sitting ever since. I'll have some time a little later on to check it out, but what are some possibilities? First thing I can think of is the handbrake cable is stuck on, or something along those lines. Didn't really check the passenger's side, but that one might be stuck also. Any help would be greatly appreciated. Will take pics tonight when I get it taken apart. Thanks alot.
    2000 S4, Autothority chip, H&R Sways, basically stock..
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Re: Rear Brake Stuck! HELP!
    was the wheel hot? was the rotor discolored?
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    ive seen caliper retainer spings break causign the pads to sit on the rotor... also could be a frozen caliper
    Q7, Q7, F-type manual
    I had a similar problem. The rear caliper wasn't retracting properly. Served as a great excuse to upgrade to a S4 rear brake setup.
