Results 1 to 8 of 8
    Mar 26 2008
    MA
    Where do i start?
    So i have a stock 2003 a4 1.8t tiptronic and its in need of more power. I would like to eventually build up atleast a k04 but will probably go BT. I dont have the money to do everything at once so where should i start? I am thinking of starting with an exhaust/test pipe then moving on to an FMIC and eventually a k04/BT setup and tune. If exhaust is a good starting place then what are some nice exhaust systems people are running?
    Registered Member Two Rings
    Mar 14 2008
    Springtown west of Fort Worth
    Re: Where do i start?
    exhaust isn't going to get you anything in terms of power, chip and injectors is going to get you the best bang for your buck, and it's going to be cheaper than most exhausts
    1999 Audi A6 Quattro Avant, 2005 Audi A4 1.8T Quattro, "the guzzler"
    <!--Will be missed -->
    2004 R32 T.Red traded it in since the road i live on now is to crappy :(
    2004 Phaeton W12 Black, 2003 911 Cab. MidNight Blue
    1999 Z3 Coupe 2.8, wow what style
    Mar 26 2008
    MA
    Yea i know that a chip and injectors is the fastest and easiest way to more power but if i go chip first, Then get a turbo upgrade i will have to get a new chip. Im not looking for the most ammount of power the fastest im looking for how to build up a nice BT over a few months.
    Veteran Member Four Rings mnkyA4's Avatar
    Aug 10 2004
    The City
    i would say go with a FMIC first then a exhaust. With the FMIC you will gain back some power that is lost during heat soak. I'm planning of purchasing the apikol upgraded SMIC as I'm only going K04.
    03' 1.8T A4 Avant Tiptronic ----- SOLD!!!!
    FUTURE: 2013 Ibis White Q5 3.0T
    Mar 14 2008
    why do people typcally only go FMIC why not the dual SMIC, perhaps put a nice small electric fan on both to make the heat soak a tad better for stop and go driving and extra hot days
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Exhaust, intercooler, then clutch. Those will be the three biggest things before you actually have to get a turbo setup and some software. Other things you will want to get and just have on the side or even put on are DV, test pipe, and a TIP
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    You are going to get varied responses here since every one has there own method or reasons as they move towards the BT... I am in the same process, I went intake(I know not necessary but I like it), DV, Exhaust, new set of coils (lots of miles on them), and now I'm saving for GIAC FX. I spoke with my shop and the savings for holding out for a complete KO4-15 set up is minimal since you already have the base software and injectors. The exhaust I went with is AWE cat back, and it is awesome, tons of good comments from friends and strangers, not as raspy as the video on AWE... good luck
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    Thought tiptronics are autos with the little side thing for shift up and down? does that have a clutch?
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
