Results 1 to 12 of 12
    Veteran Member Three Rings XCELR8's Avatar
    Jan 23 2008
    NW Indiana
    Dealer didnt reset oil change light. Can I do at home?
    Dealer says it has to be done at their shop. This true? Really dont want to drive all the way over there again.
    Aug 22 2007
    2006 A4 QTM6
    forest hills queens, ny
    Re: Dealer didnt reset oil change light. Can I do at home?
    no, just read your manual, the steps are there. makes me wonder if your dealer really changed the oil if they were too lazy to reset the light =T
    Jan 23 2008
    NW Indiana
    ok thx. lft the manual in the car so i haven't looked yet. ill check the oil tonight as well.
    Jan 23 2008
    NW Indiana
    manual says it will show dashes for the first 300 miles then it will give a mileage interval. so all is good, they did their job!
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    Be careful. My mom took her B5 in for an oil change and she got it back with the oil light on so she assumed theyjust didn't reset it. Well, they didn't even put oil in it. Make sure they did their job.
    Jan 23 2008
    NW Indiana
    checked the oil, looks good and they did replace the air and cabin filters, reflashed ecu for the update, spark plugs, etc. gotta love free main till 50K!
    Apr 03 2008
    Istanbul
    For European A4...
    Turn off the ignition
    Press and hold the button on the left side of the display
    while turning the ignition on Service OIL will be displayed
    Pull out the button on the right side of the display until the service prompt is cleared
    The display should now read ---
    If the above procedure does not work, outlined below is an alternative procedure:
    With the ignition off, push the right button
    Turn the ignition on and then pull the left button
    This should clear the warning message
    Veteran Member Three Rings ThatGuyAlex's Avatar
    Jan 24 2008
    NorCal BayArea
    Quote Originally Posted by sinana View Post
    For European A4...
    what button are u pulling?
    Established Member Two Rings mikecheck's Avatar
    Oct 05 2005
    VA
    yeah someone help I am following the directions in the manual but it doesnt work! I also dont know what button you are saying to 'pull
    USP CLUB MEMBER #81
    Jun 08 2007
    Call me stupid, but I've been reading the manual for the past couple of yrs and still can't find the instruction, pls tell me which page to find this instruction.
    Senior Member One Ring
    Oct 10 2007
    u dont pull anything on the new a4 all u do is turn key off press and hold the wrench button while turning ignition on let go and then press the button with two 0 on it
    Veteran Member Four Rings 80sGuy's Avatar
    Oct 09 2007
    Miele S7
    Why in the world would any dealer charges you $100+ dollars for oil service and not even touch the car to begin with? I'm not saying that this is true, but I would throw a big fit if I ever find out that they:
    1. take my money,
    2. waste my time,
    3. left my car sitting in the shop
    and
    4. left for lunch with my $$$ while my car sits in the shop.
    2008 A4 2.0T | Dolphin Gray Metallic/Dk Gray | multitronic | Bluetooth | Dk Wood | Convenience. | Premium. | Sprt Susp. | Bare-bone 100% factory stock!
