Results 1 to 24 of 24
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    S4 Engine noise prt2..Vid inside
    Okay, some of you might remember a few months ago, i had a strange noise coming from the front of my engine...Here's the first vid:
    http://www.youtube.com/watch?v=IrmwNTgab_Y
    Now that turned out to be a bad waterpump pulley. It damn near broke off...I dodged a bullet there..[O_O] So I've gone throu and did my whole timing belt/waterpump service.
    Now about two months later, I started hearing this noise every morning, when I start it for the first time. To me, it sounds like either my waterpump or powersteering pumps are running dry. I tends to stop within a couple minutes of starting. Here's my second vid:
    http://www.youtube.com/watch?v=OjTR8yRRaqs
    So does anyone have any ideas? I am not low on coolant or PS fluid, nor do I see any signs of leaking. My car hasn't marked her spot since I did my timing belt. The car runs great, no overheating at all.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Active Member Four Rings FrimmelNoJerz's Avatar
    Sep 21 2006
    Norjerz
    Re: S4 Engine noise prt2..Vid inside
    is the sound rpm dependent?
    does it remind you of this? http://www.youtube.com/watch?v=zFXQc...eature=related
    SBSC
    I also like to live dangerously.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    sounds like my car, i thought it was my ps pump, so i changed that, the sound is still there. I think its my accessory tensioner that is making the noise. Keep me informed if you find out the sound. Mine was there before i did my tb/wp and there after so it wasnt the water pump.
    Nov 10 2004
    Longview, WA
    Quote Originally Posted by FrimmelNoJerz View Post
    No it doesn't sound like that, but my car did sound like that in my first video, when my waterpump nearly broke. Thats not your car is it frimmel?
    And it doesn't seem to get any louder at higher RPM. So i dunno.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Nov 10 2004
    Longview, WA
    Quote Originally Posted by infinkc View Post
    Well that makes me feel a little better. I was really hoping it wasn't gonna turn out to be a bad waterpump.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Veteran Member Four Rings AB18's Avatar
    Dec 17 2004
    US
    I will put money that second one is the power steering pump. One mine for some reason, if the fluid is to low or even to high it screams like that.
    2001 S4 6sp...has a few goodies...and JHM shifted
    Tons of parts for sale..
    GIAC A box ECU for sale-350shipped.
    http://www.audizine.com/forum/showthread.php?t=170072
    Sep 21 2006
    Norjerz
    Quote Originally Posted by Kruat View Post
    hahaha where were you like.... uhhh 4 months ago when i posted that. yea its my car. my water pump went a month ago and fucked my life as i know it. im currently rebuilding my heads.
    SBSC
    Nov 10 2004
    Longview, WA
    lol ya i remember...i just thought it was your belt that broke...i missed the waterpump part...lol
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Sep 21 2006
    Norjerz
    yea way to be, asshole...
    i kid. but really...i cant believe everyone and their mother has heard that coming from my car for well over a year and noone could diagnose it.
    SBSC
    Nov 10 2004
    Longview, WA
    Ya thats too bad, my father in-law picked it the first time he heard it..lol
    But you know it'll be worth it once your car is back on the road...
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Feb 29 2008
    Durham/NC/Southeast
    It sounds like the serpentine belt tensioner but you need to take the serpentine belt off and see if it is still there to be safe. Did you use an oe pump or aftermarket? The aftermarket pumps are total junk. I have seen them go in less then 10k miles. Also I assume you replaced both rollers also when you did the timing belt. Don't let this go though cause we all know it could be really really bad.
    Mar 22 2005
    2019 RS5 SB / 2017 Jeep SRT
    FL
    I agree, sounds like the serpentine belt tensioner. When mine went it sounded exactly like that. I actually replaced my powersteering pump thinking it was that. Noise was still there and a few weeks later the tensioner failed completely.
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    turn your steering wheel and see if the sound gets worse or better if so its the ps pump. Mine just went last week! if not ide say serpentine belt tensioner,
    Dec 06 2007
    Calgary, AB, Canada
    Take off your serp belt and try spinning the tensioner pulley. It should spin freely. If there is resistance or it sounds like a grinding bearing, replace it. Then try watching the PS pulley when the car is idling. If you see play in it (movement), then chances are the bearing is going and the pump is causing the noise.
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by Dr. Jekyll View Post
    ill try and post up the sound mine is making, but it does sound identical to the second sound clip, my tensioner has been making this noise for about 30k now. guess its time to replace it.
    2000 s4
    Fairfield, CT
    its your secondary air pump humming. its not bad its just loud it works for 1-2 minutes dsuring start up to help lean out your a/f ratio for emissions. thats all.
    i heart my s4
    2000 s4
    Fairfield, CT
    now that i hear it def your air pump
    i heart my s4
    Mar 22 2005
    FL
    Quote Originally Posted by rms-s4 View Post
    If he's a 6-speed then he doesn't have air-injection. And I've heard a bad air injection pump and that sounds nothing like it. My money is on the tensioner pulley. It's actually a pretty common problem on higher milage S4's.
    2000 s4
    Fairfield, CT
    by the way. YES it does. 6 speed or not. air injection is an obd2 requirement, its there. its not dependent on what flavor trans you have. this is what i do for a living. and a belt tensioner noise wouldnt go away after a short time it would be there all the time.
    i heart my s4
    Mar 22 2005
    FL
    So is my 01.5 6-speed a factory freak because I don't have air-injection?
    umm no. 6-speed S4's don't have air injection
    http://forums.audiworld.com/s4/msgs/2767778.phtml
    http://forums.audiworld.com/s4/msgs/2114930.phtml
    http://forums.audiworld.com/s4/msgs/2067253.phtml
    http://forums.audiworld.com/s4/msgs/2507296.phtml
    I can keep finding more... but you get the point
    Oh and yes, if it's the tensioner pulley the sound does go away after a couple minutes. Mine did. Probably something to do heat, metal expansion and the like. When it was just about to die, the sound was there all the time. But for the first month or so the sound would only be there on initial cold starts.
    Nov 10 2004
    Longview, WA
    Yes i'm a 6spd, so no air pump. I hope to get some time this weekend to take the front off the car and take a closer look.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    Dec 06 2007
    Calgary, AB, Canada
    Dr. Jekyll is right.
    rms,
    sorry man, but only tips have secondary air injection.
    infinkc,
    Definitely change that tensioner ASAP. If it seizes it will likely snap the belt and leave you stranded and calling a tow truck.
    Dec 06 2007
    Calgary, AB, Canada
    No need to take the front off. Just reach down with a 17mm wrench and take the tension off of the tensioner pulley. Take the belt off. Then do as I suggested above to figure out the problem. Maybe try watching the PS pulley before removing the belt though, then take the belt off and check out the tensioner pulley.
    Feb 29 2008
    Durham/NC/Southeast
    Begs the question for how long?
    No sai on 6 spds until the late all roads. Of course a serp belt tensioner could make noise and then stop once it warms up. This is the sort of internet advise that ends up with a broken serp belt going into the timing belt cover and taking out the timing belt. Bottom line he needs to check the car or have it checked.
