Results 1 to 21 of 21
    Dec 05 2007
    Mods for higher mileage vehicles
    I just went to get my car diagnosed at a place for things to get my car in tip top shape before I start to mod (as I will have some money coming in soon). But the place I took my vehicle to also does tuning and I asked him about mods. He was telling me that with the mileage on my vehicle (112k), it is not safe to add a chip that adds so much hp&tq as it puts an extra strain on an older engine. He suggested a weaker chip such as Stratosphere and exhaust (he said something about turbo timer, but I do not mind sitting in my car for an extra minute or so). But I wanted a Dahlback, which he strongly disliked, or a GIAC x chip. What are your opinions on getting a chip for a vehicle this age (01) and this many miles (112k) and what you think effects on the engine could be?
    and for your bt guys, I am sure you dislike this inquiry. but your opinions would be very much appreciated. thanks!
    Sep 17 2006
    07 cbr600
    Re: Mods for higher mileage vehicles
    Im sure there will be a ton of people here telling you that they have way more millage then you and have been chipped since forever ago or BT since 1XX k miles. Personally i have about 106k miles and have been chipped since 92k(?). If your properly maintained 112k miles is nothing.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Start with a compression and leak-down test to assess the mechanical health of your engine.
    If those numbers are acceptable then I see no reason to modify the engine.
    -Doug
    Sep 17 2006
    07 cbr600
    If those numbers are acceptable then I see no reason to not modify the engine.
    Is that what you meant?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by Russell2686 View Post
    No.
    If the compression and leak-down numbers are within spec then I see the risk of modifying the engine (flash, bt, etc) is low.
    -Doug
    Dec 05 2007
    There are 2 things I want to do to my vehicle first ($700 job parts and labor) that the mechanic said should have my car in tip top shape. He is a brother of a person I know whom works in an Audi dealership. So, after that, how would I do a compression test? As you might have noticed, I am not the most knowledgable when it comes to car mechanics.
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    Dahlback is def the best chip out there, no question. I had mine for 2 years, and I WOULD still have it if I wasn't going BT.....its the smoothest and most powerful chip....very reliable....but pricey
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings arorem's Avatar
    Mar 24 2008
    '99 A4 1.8TQ, '74 Triumph Spitfire
    Illinois
    I think some [eople fail to realize that these kind of cars are made to last way longer that just 100k, but thats no reason not to maintain them, but 112k isnt shit, and if you plan to fix the existing problems than there is no reason not to mod it, so mod on.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    So, after that, how would I do a compression test? As you might have noticed, I am not the most knowledgable whe it comes to car mechanics.
    Here.
    http://www.audigeeks.com/forums/index.php?topic=2769.0
    Fairly simple to do and Harbor Freight has cheap compression testers (clicky click).
    Leak-down is a little bit more complex. Typically not conducted unless your compression test shows poor results. Its used to help verify what is going on (bad valve seats or piston rings).
    -Doug
    Senior Member Two Rings itsbigj05's Avatar
    Nov 28 2007
    ducati 696 and mg midget
    Pittsburgh
    my car was chipped at 30k and it now has almost 120k on it. it still runs great and hasn't had any major problems
    Dec 05 2007
    Thanks. I will more than likely bump this thread in a couple weeks (2-3) with update.
    Veteran Member Four Rings Overboostin's Avatar
    Mar 15 2007
    New England
    Yeah, If your car is fine, then there's no problem modding it.
    the homebrew'd s4
    Registered Member Three Rings Rhinop21's Avatar
    Mar 04 2008
    West linn, Oregon
    I chipped my car at 115k and the engine is still running fine but the turbo is starting to show wear. The bearings chatter and it screams after a little wot. im buying a new ko3s for 275 so that problem will be fixed.
    http://i200.photobucket.com/albums/a.../dopeaudi3.jpg
    1998 A4 sold
    1995 Talon tsi awd. 6 bolt swap.
    Account Terminated Four Rings
    Oct 28 2006
    GT30r'd A4 on Meth, 01 Durango
    i went BT at 136,XXX and beat the shit out of my car
    Senior Member Two Rings mainer0311's Avatar
    Dec 05 2007
    01 mk4 tdi
    Durham, NH
    I've got 257k on the clock and have been running a PC-16 set up for 2k miles. I plan on going 2871r come summer time. The way I look at it is I'll rebiuld it when it blows, no sense fixing what isn't broken yet.
    coop
    Dec 05 2007
    Quote Originally Posted by mainer0311 View Post
    coop
    257k!!!!! Just made me reconsider my vehicle. Now I plan on keeping her for longer than I originally planned. B5 power
    Oct 06 2004
    Minnesota
    You will be fine. I have 142K and still pulls strong with the T28
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    ^^ Damn, some of you guys have these B5's going long and hard.
    hehe.
    But yeah, proper maintenance will help your car last long. Im at 120k now and going BT in the next couple of weeks.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Senior Member Two Rings turboquattro's Avatar
    Jan 24 2007
    98.5 a4 1.8tqms
    Bothell, wa
    Ive been running a TAP stage 3 kit since 70,000 miles and now im at about 140,000. No major problems other than the timing belt which had to be replaced anyway.
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Here.
    That was an awesome DIY. Thanks for the link
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    coop
    And you are a mechanic's dream customer. The WHOLE POINT of fixing things that aren't broken yet is because when something finally breaks, it is too late. Easy example of this is timing belt. Would you wait for it to snap before changing it?
