Originally Posted by
nicko
was 04 the first year they put the sport suspension on all 2.7t's? I'm assuming the drop that spring manufacturers are talking about is compared to regular suspension and not the sport suspension. Gigi, im loving the stance of your ride. Wheel well gaps are perfect. any issues with rubbing on your 19's? what did h&r claim on the springs you bought, 1.5" drop? I'd love to go with the same suspension as your but with 20's, i just dont want any issues with rubbing.
Thanks. If you're talking about the pics in my sig, then at the time I had Koni Yellow/sport adjustable shocks (about $600 I think) and H&R sport springs. They claimed 1.75/1.5 lowering. My car sat at about 24.5/24.75 inches. It is low for an A6, I could not even slide a finger b/w the fender and wheel up front. Car handled awesome and looked bad! But it was harsh, would have been fine if it was just me but i drive with mykids and wife in the car so I chnaged the suspension to Koni FSD's and Eibach. A little higher in front, a good bit higher in the rear and 80%+ of comfort ride with improved handling... so a good compromise. It doe snot look as "bad" now! More civilized.
back to the H&S, I had the springs only first and the car bounced too much on OEM shocks, they'd wear in a hurry, I would bottom out and rub in most corners. So i got the Koni Yellow shocks installed and the car just sat lower... It ride much firmer, no mroe bouncy, nust harshness on bad roads but less rubbing too.
19's rubbed a little under heavy load. I melted the liner a little. No biggy though. I did remove the screw that holds the middle top of the liner to avoid rubbing against it. I had 245/35/19 tires too on a 8.5 wide rim and Et38. before I had 19x8.5 Et35 rims with 235's.
